07-10-2022, 12:09 AM | #1 |
Diagnosing knock
I bought a used Chevy 350 a while back, was told it ran fine... it needed pushrods installed and valve lash set. It was my first time doing it but I followed a guide very closely.
Now, a couple years later I just got the engine running. I used an oil priming tool first, etc. There is a knock, and using a stick I hear it loudest in the middle of the passenger bank off the exhaust manifold. Any tips on how I can tell if it is a misadjustment in the valve train vs a problem with the lower end?
1968 GMC 3/4 Ton 4x4 K20 / 2500 1971 Chevrolet Chevelle Malibu |
07-10-2022, 07:32 AM | #2 |
Re: Diagnosing knock
Well you could do a running valve adjustment to rule out any errors there or post a video of the knock and get some opinions here. To me a bearing knock is a deeper sound than a lifter noise.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
07-10-2022, 09:04 AM | #3 |
I had a problem last year where I could not find where the knock was coming from and it was carbon knock after I took the heads off
07-12-2022, 12:58 PM | #4 |
Moderator
You sure the exhaust manifolds are not leaking between the manifold and the head?
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
07-12-2022, 09:55 PM | #5 |
Exhaust leak on the intake crossover can sound like a valve tick. If the intake gaskets are new, re-torque the intake bolts. If you reused the old ones, might be time for a new set.
Sometime belt driven accessories can make noises that sound very much like bad engine noises. Before you start taking the motor apart, remove the belts and briefly run the motor. If the noise is gone, you have your answer. |
07-13-2022, 10:54 AM | #6 |
I guess he fixed it. Hasn,t been back. I,m curious what is was after all that fight I had with my motor
07-13-2022, 01:48 PM | #7 |
You could get a stethoscope for auto use.
They sell them at the Box stores. That will narrow down your search
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
