07-15-2022, 09:09 PM | #1 |
Need some info
I have a 465/205 combination that I bought 15 or so years ago and put in my Jeep. No tag on it. It’s all together in the truck so I can’t see what input it has. I took the front output off and counted 30 splines. I also need the spring and retainer and rest of the hardware for the shifter stick where it goes into the top of trans. I’m looking to order parts to at least reseal both trans and tease. When they talk about the 32 spline upgrade are they talking about input or output? Any upgrades that should be made? Thanks
Posted via Mobile Device |
07-15-2022, 09:25 PM | #2 |
Post Whore
Re: Need some info
32 spline upgrade is for front output shaft
205s are very tuff...if it needs seals ,id just reseal it and roll with it ORD has seal kits as do many other suppliers https://www.offroaddesign.com/np205-...asket-kit.html for sm465 parts you might look to novak https://www.novak-adapt.com/catalog/...s/sm465-parts/
07-15-2022, 09:45 PM | #3 |
Re: Need some info
I don’t believe that there is anything really wrong with it. It drives fine and doesn’t pop out of 3rd gear or whatever I have been hearing about. It just really has a bad external oil leak. That’s it. I also have to change the front output yoke to a fixed one to get a driveshaft for it. Thanks for the response.
07-16-2022, 11:28 AM | #4 |
Re: Need some info
Front output should already have a fixed flange on it. Keep the flange, they are stronger than a yoke. Stock flange should take the GM 3V ujoint, size wise they are inbetween a 1310 and 1350 u-joint---which makes for a pretty damn strong CV assy. That is unless you're rock crawling and running 37'' plus tires. the front joint at the pinion is the weak link and also the 'fuse' so to speak
07-16-2022, 11:45 AM | #5 |
Re: Need some info
Ok. Thanks. It’s a CJ8 so it should be light and it has a 250 6 cylinder in it so not a lot of power. Running 35’s and still have the Dana 30 with a Detroit locker and 4.56’s. Plan on getting chromoly axles for it. AMC 20 in back with 1 piece axles Detroit locker and disc brakes. I’m going to try and mess around on some rocks but more for the mud.
07-16-2022, 06:10 PM | #6 |
Re: Need some info
Your issue is going to be with the AMC20 with bending the housing
07-16-2022, 06:12 PM | #7 |
07-16-2022, 08:19 PM | #8 |
Re: Need some info
Yup, the housings are only about 3/16 to 1/4'' thick.
07-16-2022, 08:42 PM | #9 |
Re: Need some info
Ok. Good to know. Thanks
07-17-2022, 12:27 AM | #10 |
Re: Need some info
Make sure you get the gaskets for the trans and T-case when you order the seals... Do not seal with rtv or anything like that... you must use the proper gaskets with no sealant, gasket only. Just in case you didn't know.
j
White K20 |
07-17-2022, 12:48 AM | #11 |
Re: Need some info
An add to that would be to go over everything with a good flat file to knock down high spots and sharp edges, both on the case and retainers
07-17-2022, 12:18 PM | #12 |
Re: Need some info
Ok. It’s been a while since I put it together but for some reason I am now thinking that I used etc instead of gasket. I am going to order all the seals and gaskets and start there. Are all the kits the same? I know I have the figure 8 tcase adapter and the trans has a cast iron top. Thanks everyone for the info
