07-17-2022, 10:04 AM | #1 |
Flex fan
I need advice on a replacement fan for my1969 C10. It has a 350 I have heard that the flex blade fans come apart. Is that the case?
07-17-2022, 05:05 PM | #2 |
Re: Flex fan
Yeah, many Youtube videos seem to agree. I like the biggest 6 blade clutch fan that fits the shroud and a Hayden 2747 clutch for a stout small block with an automatic.
Edit: most fans have a "replace after x amount of miles" warning label on the box. |
07-17-2022, 11:35 PM | #3 |
Moderator
Re: Flex fan
And they now make a 2947 fan clutch that is shorter.
07-18-2022, 02:44 PM | #4 |
Re: Flex fan
Flex fans don't do anything.
Electric fan or clutch fan are the way to go. |
07-18-2022, 04:38 PM | #5 |
driving is in my blood
Re: Flex fan
Had a flex fan on my 78 for the last 25yrs. Works fine. Doesn't explode.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
07-18-2022, 06:30 PM | #6 |
Re: Flex fan
This video is really good. https://drivemag.com/video/cooling-f...-masters-ep-20
07-21-2022, 08:35 AM | #7 |
Re: Flex fan
I am unsure if the flex fans design has changed but the typical flex fan has symmetrical blades. As in, all blades are spaced evenly.
This design will make you motor sound like a jet. Factory fans appear like they are missing a blade, this design is why they are quiet. It doesn't affect the balance because of how they are built. I notice more than a few factory fans on eBay. Consider using a clutch and factory fan. They just plain work and are quiet and according to the video use less HP. Thank Dave, for the link. The engine masters video was excellent but they didn't mention or measure the fan noise. Likely would have been impossible in the dyno room anyway. Cheers. Last edited by Accelo; 07-21-2022 at 09:18 AM. |
07-22-2022, 12:43 AM | #8 |
Re: Flex fan
My fan is one that is evenly spaced and I bought it new at O'Reilly's. I 've seen those odd spaced ones before and wondered what the deal was. Quiet is good, although I wouldn't say mine is loud really. When it comes to engine fans though I am leary of getting one with the potential of having a lot of miles on it in case it may be structurally compromised somehow. One thing I was able to do when I got a beefier radiator was to swap my heavy duty 2747 clutch for the standard duty one which did slow the fan a bit and helped the noise. The thing about a short pump 283 is that a single groove pully has a larger diameter than a double and when I had to go with a double, it spun the bleep outta the fan until I went with the standard clutch.
07-22-2022, 09:44 AM | #9 |
Re: Flex fan
Worked great for 37 years . I just replaced the original that is stamped 1985 so it’s original to the truck . I kept it maybe it can be rebuilt ? This is a new Hayden unit
07-27-2022, 04:11 PM | #10 |
Re: Flex fan
Thats a clutch fan not a flex fan?
07-28-2022, 09:11 AM | #11 |
Re: Flex fan
I know just saying you really cant improve on factory .
07-28-2022, 12:16 PM | #12 |
Re: Flex fan
My C20 came with a factory 7 blade clutch fan and all I did was replace the clutch unit and it works flawlessly. It is quiet and numerous 6000 rpm blasts and no issue.
The best choice imho. |
