09-11-2020, 08:20 AM | #1 |
WTB 1967 Gmc parking lamp lens gasket
Need a source for a pair of parking lamp lens gaskets for my 1967 GMC. Does anyone here know where to find them?
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
09-12-2020, 02:37 PM | #2 |
Re: WTB 1967 Gmc parking lamp lens gasket
Have you tried GMC Paul's?
09-12-2020, 03:06 PM | #3 |
09-12-2020, 04:30 PM | #4 | |
Brothers has no clue that Chevy and GMCs parking lights are different. LMC doesn't even carry GMC parking lights, let alone the gaskets. Truck and Car Shops of Orange County, CA show the GMC Lenses [P/N 67-01005] in Amber, L or R, for $13 each. [Clear $17, p/n 67-010051] but they don't mention rivets or gaskets. However, with the Chevy clear kit, they mention 2 amber bulbs, 2 gaskets, and 2 lenses for $17. You might email or call them. 800/ 243-8947 www.TruckandCarShop.com Also email or call GMC Paul. They specialize in GMCs of this vintage.
09-12-2020, 07:08 PM | #5 |
I will give them both a call Monday. Thanks!
09-12-2020, 08:33 PM | #6 |
Correction -- Brothers does have the GMC-only amber lenses.
P/N: PLL72GM -w/rivets -- no mention of gaskets, though -- $24.99 each. Brothers discount code [exp OCT 30] FALL20 And if no one wants to play Gaskets Only, you could trace out the outline of the lamp housing, flat on 1/8'' cork gasket material*, with a ball point, then cut around the traces with an Xacto knife, and open up the inside as needed. Stick them on with a light coat of RTV. We did stuff like that before there were all these re-pop/resto parts houses, and after the dealer stopped stocking them. * From Ace Hardware.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 09-12-2020 at 08:47 PM. |
09-13-2020, 07:18 PM | #7 |
Bingo!
Mane's Truck Parts has them for $3.95 a pair: No part no. just listed as "GMC Turn Signal or Park Lamp Lens Gaskets (Pair) -- 1967-1972 Truck." www.manestruckparts.com 816/ 230-5949
09-13-2020, 07:46 PM | #8 | |
Posted via Mobile Device |
09-13-2020, 09:36 PM | #9 |
I remember buying lenses, rivets, and gaskets 15 years ago as well, I think from LMC. Checked their website and they are all still available.
https://www.lmctruck.com/1967-72-che...klight-for-gmc
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
09-13-2020, 10:45 PM | #10 | |
09-13-2020, 10:46 PM | #11 |
09-13-2020, 11:48 PM | #12 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Been using Manes for years...https://www.manestruckparts.com/
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
09-14-2020, 03:04 AM | #13 | |
09-14-2020, 11:47 PM | #14 |
Hi, It looks like you found them.. Unfortunately no one makes the actual assembly's but I found a pair in a junkyard... However, I do not have any idea what the bulb socket looks like... Does anyone have a good pic of one so I can figure out where to buy them...? Thanks in advance..
******************************************** In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks.. |
09-15-2020, 07:35 AM | #15 | |
https://www.speedwaymotors.com/Search?query=5404c Posted via Mobile Device |
09-15-2020, 10:59 PM | #16 | |
09-16-2020, 10:36 AM | #17 |
GMC park light socket is gmc only. And not reproduced. So the only real option other then fajiggling the wrong one in is to find a gmc and hope it had them and are in good shape. That what I had to do.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
09-16-2020, 02:27 PM | #18 |
One of the advantages of living in Arizona is that I don't notice stuff like that.
