05-10-2020, 04:53 PM | #1 |
fire wall insulation pad
Just mounted my fuse box and fitted my column. Still waiting on my fire wall insulation pad to be delivered. Will I be able to install around these items, or should I pull them back out? I'm getting a stock card board with jute. Looking at photos of the pad imagine it has to go in first?
05-10-2020, 05:14 PM | #2 |
All about them K’s
Re: fire wall insulation pad
You’ll have to pull the fuse box off and hang it to the side. i just did this two weeks ago on mine. The column can stay in as the insulation has a cut out to slide around it. Pretty much every thing else will have to come loose/ off of the firewall.
Odds are your going to create a few new cuss words, this was by far one of the more pita things I’ve done on my truck.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 Last edited by 57taskforce; 05-10-2020 at 06:26 PM. |
05-10-2020, 10:48 PM | #3 |
Thanks, I was starting to feel that way. Guess I got a little excited over the parts in hand!
05-11-2020, 08:48 AM | #4 | |
Is it a hijack if I ask about installation of the other 2 pieces of insulation?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-11-2020, 10:31 AM | #5 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
05-11-2020, 01:10 PM | #6 |
Thanks for the quick reply. It sounds like I should coordinate the replacement of the insulation with the removal of the seat for reupholstering.
Good information thanks. HO455
05-11-2020, 02:23 PM | #7 |
All about them K’s
I would recommend that for sure and if your planning on replacing the carpet pull the old out or at least back as far from the firewall as you can.
05-11-2020, 03:08 PM | #8 | |
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
05-12-2020, 07:28 AM | #9 |
actually would the Dynamat style stuff be a better option maybe with a layer of spray on sound deadener underneath???
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
05-12-2020, 08:29 AM | #10 |
Alright, now you're making me spend more money than I wanted to
05-12-2020, 03:05 PM | #11 |
I was wondering if Dynamat can be used under the stock type firewall padding???
05-12-2020, 03:07 PM | #12 |
All about them K’s
The replacement insulation is probably half or a little more as thick as what came out of my Cheyenne. I think you could pull it off personally.
05-14-2020, 03:24 PM | #13 |
That is what I'm planning on doing. The sound mat has been installed for a while now but I'm not thrilled with the look of the sliver backing above the top of the carpeting. So reinstalling the OE insulation will restore the factory look.
05-15-2020, 09:35 AM | #14 |
Isn't that the name of the chevy truck game 🤔
05-15-2020, 11:50 AM | #15 |
True of any old vehicle being worked on
