Old 08-18-2021, 02:02 PM   #1
Ziegelsteinfaust
The GMC V6
I am going to build my Dad a motor for his Christmas/B-Day gift.
Besides the usual small blocks I found out again about the GMC 305 V6. As it has never been in a vehicle I own.
The engine will go into a Model A hot-rod, and my Dad is fine with a 283 or 305 on power. As he likes the sound of a V8 revving up.
Would the GMC V6 fit into a Model A easily due to its wider angle?
By chance how does one sound with straight pipes?
I think it would be cool since it is not a belly button engine, and he is game on it.
Thoughts?
Ziegelsteinfaust is offline   Reply With Quote
Old 08-18-2021, 03:54 PM   #2
Tom
driving is in my blood
Tom's Avatar
Re: The GMC V6
If he likes the sound of a V8 revving up, why would you build him a v6?
Old 08-18-2021, 04:15 PM   #3
MySons68C20
MySons68C20's Avatar
Re: The GMC V6
I think they sound like a tractor.....
MySons68C20 is offline   Reply With Quote
Old 08-18-2021, 04:17 PM   #4
Ziegelsteinfaust
Re: The GMC V6
He had a turbo Model B engine that sounded more like a Ford 7.3 IDI, and he misses it.
Plus it would be different
Old 08-18-2021, 07:32 PM   #5
cadillac_al
Re: The GMC V6
They are awesome truck engines but they aren't really fast revving or high revving. I never thought they sounded cool either and the one we had had dual exhaust. I would much rather have a 283 in a hot rod.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 08-18-2021, 09:35 PM   #6
Ziegelsteinfaust
Re: The GMC V6
The revving or lack of it is fine. I can regear the axle of needed.
Does the engine sound labored, just plain odd, and or not right?
This was a option since my dad saw one, and thought it looked cool with repop tartan valve covers.
I have a line on a 305 with low miles I could get. Then toss in a better cam, and regasket it up.
Old 08-18-2021, 10:24 PM   #7
truckster
truckster's Avatar
Re: The GMC V6
It sounds deep because of the relatively large displacement per cylinder. It sounds odd to most people because of the fact that you get 6 pulses per revolution rather than 8. I had duals with glass packs on mine, and I liked the sound.
Here's one with a stock (but old) exhaust:
https://www.youtube.com/watch?v=-7MWa5MnJBo
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is online now   Reply With Quote
Old 08-18-2021, 10:33 PM   #8
Ziegelsteinfaust
Re: The GMC V6
That sounds pretty decent. When I get my 83 back on the road I will make a decision with my dads input.
Either way it will be pretty unique when he drives around.
Old 08-18-2021, 11:37 PM   #9
truckster
truckster's Avatar
Re: The GMC V6
They pull like crazy, but they don't rev much at all. They're definitely unusual and they're about as bulletproof as an engine can get.
Old 08-19-2021, 01:20 PM   #10
mattfranklin
mattfranklin's Avatar
Re: The GMC V6
It will be cool and unique for sure. A lot harder to get parts for, but very cool. Another unique thing is that the spark plugs are located on the intake side of the rocker cover, letting you use shorter plug wires and keeping them away from the hot exhausts (factoid from Wikipedia).
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 08-19-2021, 01:21 PM   #11
mattfranklin
Re: The GMC V6
Oh, and look for the ones with plaid (I kid you not) rocker covers. They were a thing. Very unique.
https://www.google.com/search?rlz=1C...w=1280&bih=577
Old 08-19-2021, 05:36 PM   #12
truckster
truckster's Avatar
Re: The GMC V6
Yeah, when I got my first one I was really confused because the spark plugs weren't where I expected them to be.
Old 08-20-2021, 08:34 PM   #13
MusicMan70
MusicMan70's Avatar
Re: The GMC V6
Here’s and old video with duals and X pipes and Hooker Aero Chamber exhausts
https://youtu.be/yu58AWrA_cE
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 08-21-2021, 04:33 PM   #14
crazy longhorn
Fabricate till you "puke"
Re: The GMC V6
Thoughts?
In that A -bone, I would run a 283 chev....or if you want to be correct....A flat head v-8 Ford , would be the ticket. Take a Merc crank, offset grind to stroke it as far as you can....use the ford rods. Then bore the block as far as you can. Many speed parts are still there for that old Ford. Other than that, I feel that the old GMC 6 , will be heavy on the nose , of that a-bone. Just my thoughts.....Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-21-2021, 11:47 PM   #15
Ziegelsteinfaust
Re: The GMC V6
He has 2 or 3 flat heads, but won't swap them in. Claiming some bigger idea.
The 305 weighs about 100 pounds more. Which is not to bad if my dad starts to use radial tires.
I am almost done getting my 83 back on the road, and then I will let him decide. After Halloween
Old 08-22-2021, 12:28 PM   #16
MySons68C20
Re: The GMC V6
My guess is your dad is in his 80's? If he is anything like my dad was before he passed there won't be changing his mind
Old 08-22-2021, 12:54 PM   #17
Ziegelsteinfaust
Re: The GMC V6
He's 79 so there is still time
Old 08-22-2021, 08:31 PM   #18
cadillac_al
Re: The GMC V6
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 04-26-2022, 09:26 AM   #19
1967GMCC20
1967GMCC20's Avatar
Re: The GMC V6
V6 Heavy engine..... make a big block feel light. I have a rear cross member, front mounts for V6. And a power steering pump hydroboost that was on it. Free u pay shipping.
1967GMCC20 is offline   Reply With Quote
Old 04-26-2022, 03:09 PM   #20
Ziegelsteinfaust
Re: The GMC V6
The V6 fell through. He stole another 350 engine from me, and bought another flat head to use. It was a cheap core so I would of sold it either way, but he traded it for a couple of rims I think.
Now he says he needs my 383 LT1 short block, but has no car for it. I told him buy the 59 Chevy truck you have had your eyes on. Then I will build it.
Plus I have not seen a V6 listed for a minute.
Old 04-28-2022, 07:54 PM   #21
AcampoDave
AcampoDave's Avatar
Re: The GMC V6
If was gonna build a six, I would use a Chevy 292 straight six before a GMC V/6. Still unusual and more fun.
AcampoDave is offline   Reply With Quote
Old 05-01-2022, 07:55 AM   #22
cadillac_al
Re: The GMC V6
I'll bet that GMC V6 is 3/4 of a 409. That's why it looks so cool.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 05-02-2022, 01:16 PM   #23
Ziegelsteinfaust
Re: The GMC V6
While a great motor. It is not symmetrical for a hotrod.
Old 05-02-2022, 03:22 PM   #24
crazy longhorn
Re: The GMC V6
Just my thoughts...An aluminum block LS would be the fit (narrow), & lite on the nose of an old A-bone! That lite weight A bone wont need more than a stock 5.3/5.7 . Longhorn
Old 05-04-2022, 07:25 PM   #25
biketopia
Re: The GMC V6
An LS4 would be the ticket. It's a 5.3 out of a front wheel drive car, is a narrower block vs a your run of the mill truck 5.3. Look up LS4 king on social media.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
