10-04-2020, 07:10 PM | #1 |
Por 15
Severely disappointed in POR 15. 3 years ago I put it on the frame in the engine compartment. This truck has never been out of my garage. I took the cab off to sand blast the rust and decided to power wash the frame. The POR 15 came off in sheets. Now I have to repaint the engine compartment as well as the rest of the frame.
10-04-2020, 07:21 PM | #2 |
Re: Por 15
I do not know why it sheeted off
I have learned why bodyman wont touch por15 as it can be brittle and crack lots where epoxy paints will withstand the impact better |
10-04-2020, 07:44 PM | #3 |
Re: Por 15
How was it prepared ? Leaving rust (not loose scaly loose rust ) or sandblasting Is recommended if the metal was smooth Shiny metal it won’t adhere well.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
10-05-2020, 02:17 PM | #4 |
Re: Por 15
With any paint or coating properly preparing the surface is vital for performance. Coatings that come off in sheets is a sign of improper surface preparation.
POR-15 requires a rough surface. It adheres better to a rusty surface than a clean one. POT-15 recommends using a acid preparation before application. The POR-15 will stick to rust fine but not the surfaces around the rust. They must be prepared correctly to ensure the coatings last as expected.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-05-2020, 03:15 PM | #5 |
Re: Por 15
Just to pile on, a good wax and grease remover after some degreaser (even dish soap) will also help with long term adhesion. This is true for any coating.
If you want it quick, fast, and in a hurry- I've had good luck with a quick wire brush, brake cleaner, and a spray on 2 in 1 encapsulation product. Stuff that is spayed tends not to come off in sheets. |
10-07-2020, 06:50 PM | #6 |
Re: Por 15
I always have a hard time opening the can
10-07-2020, 07:38 PM | #7 |
Re: Por 15
I pour a little in a small jar to use in a few days. Clean the can lid and lip with xylene.
10-07-2020, 11:48 PM | #8 |
Re: Por 15
I did the floor pans in my ‘60 Buick with POR 15. Used a burly cup brush in my 4 inch disc grinder to clean, derust and roughup the metal. 10 years after the fact I recently had to remove the carpet to replace the heater core. Out of curiosity I tried to chip or pull up some of the edges of the coating. Man that stuff is ON there!! Can’t even begin to peel that stuff off the floor! Just my one time experience ........
Steve weim55 Colorado |
10-08-2020, 12:13 AM | #9 |
Re: Por 15
I have had it on the frame of my GTO for 15 years, still adheres fine. Agree there was probably a prep issue?
10-08-2020, 02:50 AM | #10 |
Re: Por 15
I use small cans of POR-15 fuel tank sealer to restore kerosene lanterns and can seal 6-8 per can. I drill 2 holes in the cover and close them up with #10 sheet metal screws between projects. Next time I need it I shake the can, remove the screws, and pour what I need. You can stir it with stiff wire through the holes if you want.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke 2007 BMW X3 2020 BMW 540xi 1995 Harley FLSTC |
10-08-2020, 04:52 AM | #11 |
Re: Por 15
Try SPI Epoxy. Many will speak to its superior attributes. Follow the application instructions to a TEE!
You will not be disappointed. The company owner IS hands down top notch. The product is affordable also. Sign up for their user forum and do your research. http://www.spiuserforum.com/index.php |
10-08-2020, 10:47 AM | #12 | |
Re: Por 15
THIS is what you need: www.rustbullet.com Here's their Frame kit: https://www.rustbullet.com/product/u...riage-car-kit/ RB is THE BEST rust inhibitor.....PERIOD!!! (As Greg Gutfeld would say) I used and I've never had any issue and I'll never have to use it the same area ever again. (Of course keeping my truck in a garage helps too) But, I'm telling ya, do the research and you'll see.
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary Last edited by 96blazr; 10-08-2020 at 10:54 AM. |
10-08-2020, 10:59 AM | #13 |
Re: Por 15
Mine's been fine for years. I like the small cans to use one at a time and not have to store a previously opened can. I used their metal prep as suggested.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
10-08-2020, 07:00 PM | #14 | ||
Re: Por 15
10-08-2020, 07:37 PM | #15 | |
Re: Por 15
"RB is THE BEST rust inhibitor.....PERIOD!!! " Which commercial marine hull and deck coating systems did you compare this inhibitor to?
10-09-2020, 04:37 PM | #16 |
Re: Por 15
I'm told POR is a urethane base. Urethane is good stuff, but 2-part epoxy is better. I personally use epoxy since I can get a gallon of activator and a gallon of base (1:1) for the price of a gallon of POR. Epoxy has excellent adhesion on raw steel and when cured is really tough. So tough, it resists a wire wheel. Also stands up to salt and most chemicals although brake fluid will remove the gloss.
As previously mentioned, adhesion is dependent on prep. Nothing will stick to an oily substrate. A good method for underbody and chassis is to wash everything with soap and water using a scotch brite. Then wire wheel or blast any scaley rust. This is followed by a phosphoric acid wash with scotch brite. Then comes the epoxy. Use a roller anywhere possible since it makes for a high build, single coat, and then use horse hair and/or sponge brush for the nooks and crannies. Once finished, it does not come off. You can take a hammer and beat on it, it will not chip and will not flake. EDIT: Forgot to mention, the epoxy I use is from Anchor Paint (local manufacturer for me). It is an industrial grade, high-build, polyamide coating (highly toxic which means it works), p/n 3900. Anchor can dye it various colors, although I prefer black which appears semi-gloss once applied with a roller. It is not UV resistant, and will eventually color fade if applied to surfaces exposed to the sun.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs Last edited by bry593; 10-09-2020 at 04:48 PM. |
10-09-2020, 07:26 PM | #17 | |
Re: Por 15
10-09-2020, 07:33 PM | #18 | |
Re: Por 15
10-09-2020, 08:22 PM | #19 |
Re: Por 15
I tried to paint pro 15 on my frame that had been painted with 395a and starting to rust it came off in sheets
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
10-10-2020, 07:14 AM | #20 |
Re: Por 15
It seems every time these coatings come up it ends up in a pissing match between brands. It is obvious this thread was started due to improper surface prep which is no fault of the product. It seems ironic, but the problem here was the surface was probably prepped too well. Or maybe the surface wasn't rusty in the first place and it's use was overkill.
I've used these coatings for a very long time, powder coat as well. Like 40 years or more. Way back when my powder coater told me they do epoxy for interior and poly or whatever the other was... urethane?... for exterior because the epoxy had less give, less tolerant to extremes. But that was a long time ago and I know chemistry in this area has come a long way. There are strong opinions on these products that POR-15 was the pioneer for. That's Paint Over Rust-15. I know people who used it back when I used to who are still happy with it. I switched to Masterseries when I learned of it and educated myself on it vs POR-15. Recently I have learned about the SPI that many members promote with passion, and have also been made aware of some stink going on between those two companies. I think it's a waste of effort to play into that one bit, and I certainly have not and will not. I believe there can be more than one great product out there that will meet and exceed your expectations, just like tire companies and many other things we buy for our trucks.
10-10-2020, 12:51 PM | #21 |
Re: Por 15
What he said!
10-11-2020, 10:12 AM | #22 |
Re: Por 15
I used POR-15, for the first, on my sandblasted frame just to make sure it didn't rust. I used a brush to spread it on. Since POR-15 breaks down if exposed to UV light I sprayed on some gloss black paint. After all that was done I wanted to run a ground wire to the frame. The only way I could get to clean metal was to use a die grinder with 80 grit.
So that is my experience with POR. If you prep the surface right it works great.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
