05-13-2020, 11:39 PM | #26 | |
Re: What's the deal with radiator cap rating and coolant systems?
I had the impression a tank was the better option. After reading this thread it appears it doesn't have to be.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-13-2020, 11:59 PM | #27 | |
I put one on my Longhorn because it's a big block. As it turns out, it's the coolest running big block I have ever had. What ever cap you use with the tank, it needs the arrows on it. One arrow will point to the overflow tube. I called that tank NOS. That was not intended to insinuate the tanks were available from the factory on our trucks.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
05-14-2020, 12:16 PM | #28 | |
Believe or not the expansion tanks were available from factory on rare occasion. Shows on the SPID and I believe those were Govt. trucks. The only question I have is did they use the blue cap per kit instructions or leave the better cap in place
05-14-2020, 12:21 PM | #29 |
Carpe manana
I'll trade an RC15 for your blue cap.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
05-14-2020, 04:38 PM | #30 |
I may have missed it, but what kind of cap did the trucks with factory installed overflow have?
05-14-2020, 07:37 PM | #31 | |
Not sure what I'm doing with it. If I were to be tempted by an RC15 then it depends on the RC15
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-14-2020 at 07:55 PM. |
05-14-2020, 08:33 PM | #32 |
I have never seen a coolant overflow on a SPID on a 67-72.
05-15-2020, 12:49 PM | #33 |
[QUOTE=davischevy;8738865]
What ever cap you use with the tank, it needs the arrows on it. One arrow will point to the overflow tube. /QUOTE] I guess nothing is absolute. I should have said "unless closed system is noted on the cap".
05-15-2020, 02:51 PM | #34 |
Proprietor of Dale's Corner
It definitely needs to be a recovery type cap. A closed system cap will push it in the tank but will be unable to draw back to the radiator.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-15-2020, 03:08 PM | #35 |
You got me there. I can't seem to locate the thread on the topic. If I remember right it was concluded best guess some govt. trucks were stocked with the coolant tanks & SPIDs to match.
Here's one, post 5. I don't know enough to tell what year this SPID is, and I can't read the RPO code. I'm surprised nobody commented on it: Post 5 http://67-72chevytrucks.com/vboard/s...d.php?t=546610
05-17-2020, 11:54 AM | #36 |
BOOM! This isn't the SPID I recall but good enough. 72 Chevy, RPO 8B6, which matches the SPID I linked to earlier.
Post 21: http://67-72chevytrucks.com/vboard/s...d.php?t=560500 Rare enough the RPO isn't included here: http://outintheshop.com/options.html
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-17-2020 at 12:27 PM. |
