Old 01-13-2011, 01:18 AM   #251
swamp rat
swamp rat's Avatar
Re: Project “Learning as I Go”
Originally Posted by 67chevy1series View Post
what type of dash did that go on
He mentioned it about 6-8 posts ago.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-13-2011, 01:28 AM   #252
kvn1011
Kvn1011
kvn1011's Avatar
Thumbs up Re: Project “Learning as I Go”
02 Camaro
cant wait to see how that turns out!!
kvn1011 is offline   Reply With Quote
Old 01-13-2011, 01:33 AM   #253
67chevy1series
67chevy1series's Avatar
ya i had just found it thank you
67chevy1series is offline   Reply With Quote
Old 01-14-2011, 11:05 AM   #254
JohnC
JohnC's Avatar
Column looks good man. Only concern I have about the gauges is that that seems to be running a little high on the rpm's for where you are in this stage of the process. I think they look good in there. Not what I would run, but it's not my truck. If we all did the same thing then this hobby wouldn't be nearly as fun!
JohnC is offline   Reply With Quote
Old 01-14-2011, 12:01 PM   #255
gopokes
gopokes's Avatar
She is running a little high. I'm not even 100% sure I will like them after I get them done either, but it will at least give me cheap working gauges for the time being. I'm sure sometime down the road I will change them out, but who knows maybe they will grow on me. I'm just trying to get this thing back on the road, because if i don't get to drive it soon, I'm going to pull my hair out!
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224
gopokes is offline   Reply With Quote
Old 01-16-2011, 04:47 PM   #256
JohnC
JohnC's Avatar
Careful I used to say that, and needless to say I don't have much hair anymore.
Old 01-16-2011, 07:57 PM   #257
swamp rat
swamp rat's Avatar
Originally Posted by johnc View Post
Careful i used to say that, and needless to say i don't have much hair anymore.
++1!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-23-2011, 08:39 PM   #258
RCbowtie69
RCbowtie69's Avatar
Hey from N.C. just check out your build & it's looks like it coming along, like when u fire the engine up, u r making progress
RCbowtie69 is offline   Reply With Quote
Old 01-23-2011, 10:49 PM   #259
gopokes
gopokes's Avatar
Thanks man, I haven't gotten anything done lately. My brother got me a little distracted, he bought a new toy and got me really distracted. This isn't actually a pic of his, but it is the same thing.
We went to the range today, this thing is freaking awesome! I know I don't need one of them, but I really want one now. Hopefully I will get some work done soon.
Old 02-06-2011, 06:58 PM   #260
RCbowtie69
RCbowtie69's Avatar
Hey from N.C. again & there's nothing wrong with that u r looking good, checking on any progress & u need to get away sometime,keep up the work & pictures coming
Old 02-08-2011, 06:58 PM   #261
gopokes
gopokes's Avatar
Thanks man, I don't have any progress to show. It has just been to darn cold for me to get motivated to go out to the shop lately. Which doesn't make much sense because we went to our annual fishing trip last weekend and it was freezing with almost a foot of snow on the ground. I'm hoping the weather will turn around so I can start making some more progress.
Old 02-21-2011, 11:31 PM   #262
RCbowtie69
RCbowtie69's Avatar
I here U man, it's starting to get nice out here in N.C.I've been colleting parts during the winter, cross member for my 700r4,that i bought at the end summer,still need a set of headers for my 350, that been bore .60 over with set of 041 heads 64cc.A set of fenders when i start doing body work,& still looking for a good driver door.Keep up the build & pictures coming
Old 03-14-2011, 10:04 AM   #263
gopokes
gopokes's Avatar
Well it's been a while since I've updated this. Really hasn't been any big advances or picture worthy updates, but I still wanted to post an update just to keep track of my progress, and ask some questions. I finally got around to buying some parts I will need to get this thing back on the road. I have my new trac bar kit ordered, and will be getting my driveshaft shortened soon. I'm kind of concerned with the strength of the original shaft since I'm using the newer engine now. Do you think I would be better off trying to find a larger diameter shaft and get it modified to fit?
I did get my gauges hooked up, they all work except for the oil pressure. I've got a question about it posted in the LS swap section, but haven't found an answer for the problem yet. I got all my brake lines ran (they don't look that great) but I think they will work. Got my radiator installed and trans cooler lines ran. I am to the point now that I can set the cab back on and see if it all fits, but I want to try to get the oil pressure gauge working first. Sorry for the rant, and lack of pics.
Old 03-14-2011, 11:54 AM   #264
JohnC
JohnC's Avatar
Sounds like you're coming right along with it. I don't think you will have any problems with the driveshaft. PM Scotts62. He and the guy that he used to work with work with driveshafts daily. They should be able to answer your questions.
Old 03-14-2011, 12:17 PM   #265
gopokes
gopokes's Avatar
Thanks man, I did talk to Scott once, but had to wait a while to actually get it done. I'm going to have him do it, but the other day I looked at it setting there and it just seemed a little puny. I guess it's more about wall thickness than diameter on that stuff. I'll send him a PM right now.
Old 03-15-2011, 10:09 PM   #266
gopokes
gopokes's Avatar
Well like I said, my brakelines aren't anything to write home about but I have to post some pics. I think I might redo the rears, I have enought line do it, we will see. I talked to Scott and am going to get the driveshaft squared away soon. Dang my frame is dirty!
Old 03-18-2011, 06:48 PM   #267
gopokes
gopokes's Avatar
Today I picked up new brake shoes, and wheel cylinders I just have to get out there and start working. I haven't worked on drum brakes for a LONG time, hopefully it's like riding a bike. The brown truck showed up a few minutes ago with my shock relocators, drop blocks and trac bar too. Figured I'd post some pics.
Old 03-18-2011, 07:46 PM   #268
jasonhall
jasonhall's Avatar
looks Good!!
jasonhall is offline   Reply With Quote
Old 03-18-2011, 09:11 PM   #269
VA72C10
VA72C10
VA72C10's Avatar
new parts are always fun
Old 03-18-2011, 10:16 PM   #270
coops714x4
coops714x4's Avatar
Hello neighbor the build is cool holler if ya need a hand Im still in the gathering stage mine is such a BIG project its gonna take some time Ill drop ya a friend request
coops714x4 is offline   Reply With Quote
Old 03-22-2011, 10:54 PM   #271
gopokes
gopokes's Avatar
Originally Posted by jasonhall View Post
looks Good!!
Thanks guys! Coops, I will definately let you know if I need a hand. Same to you though, if I can lend a hand let me know. I actually got some work done in the last couple of days. I had all of my gauges working except my oil pressure and fuel level, fuel is the easy one. But I ended up getting a Camaro oil pressure sender and it made the gauge work. I also got my trac bar, shock relocators, and drop blocks installed. I like the drop blocks because they will let me have a little more air in by bags down low, I don't really like that the ubolts are now under the scrub line. Guess that will make me get some 20's a little sooner! I also started rebuilding my rear brakes, haven't messed with drum brakes in a long time, what a pain! Anyway, here are some pics, and a little video of the gauges.
Old 03-22-2011, 10:58 PM   #272
VA72C10
VA72C10
VA72C10's Avatar
Nice work!!!
Old 03-24-2011, 02:11 PM   #273
gopokes
gopokes's Avatar
Nice work!!!
Thanks man, I finished up the passenger side last night. Then I looked at the pic of the drivers again and realized I missed getting the lower spring back in. Looks like I'm going to be pulling that back off tonight. I hate having to do things twice. I think I am going to get the cab back on this weekend, maybe even the bed, we will see. Still alot to do after they go back on, but at least it will be closer to one piece again.
Old 03-27-2011, 08:03 PM   #274
gopokes
gopokes's Avatar
Today was a good day, got the cab back on! Everything went really well, I was worried that my h-pipe might hit, but it was all good. I also got my old AC stuff pulled out, found a little mascot for the build, he was a little flat though. I also found out that the steering column shafts from the 71 and the 94 column I am using are the same size, so they will slide right together. Got alot of little stuff to finish up, but I should be driving this thing again fairly soon. Thanks for looking.
Old 03-27-2011, 10:24 PM   #275
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Awesome build! Should be driving her in no time now!
ChuckDriver is offline   Reply With Quote
