11-18-2021, 01:34 AM | #1 |
Oil pump gasket question
So I'm rebuilding a 250 inline 6 for my 1976 C10.
The oil pump gasket that came with my gasket set is not lining up to my liking (hard to explain without showing a picture) I was thinking I would rather make my own gasket but got to wondering if it matters what type of material I use to make it. Will regular gasket paper work? If so what thickness should I use? I'm only thinking about this because of the oil pressure. Is this even a problem?
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1998 chevy c1500 4.3L 5speed (My current driver) 2002 Chevy s10 4.3L auto 4x4 1971 mercury monterey wagon 400 auto To many projects! |
11-18-2021, 07:25 PM | #2 |
Moderator
Re: Oil pump gasket question
So long as the suction port and pressure port on the pump is covered by the gasket, it will be fine.
I have seen many different variations of port location etc....none of them seem to make a difference so long as the ports are fully surrounded.... Place the gasket on the pump and taje a pic and upload it...that way we can see what your concerns are...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
11-18-2021, 11:16 PM | #3 |
Edit: I guess I'm stupid I forgot to attach the pic to the post.
Ok here's the pic. Notice the gap on the upper right. And yes I have tried flipping the gasket opposite ways and it still has a gap.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1998 chevy c1500 4.3L 5speed (My current driver) 2002 Chevy s10 4.3L auto 4x4 1971 mercury monterey wagon 400 auto To many projects! Last edited by straight6chevyguy; 11-18-2021 at 11:37 PM. |
11-19-2021, 06:20 PM | #4 |
Moderator
That is the wrong gasket....that will suck air and not prime...
Post a pic of the gasket sitting on the oil pump face .....
11-21-2021, 10:24 PM | #5 |
Some more pics.
Gasket on pump. Gasket flipped around on pump. Pump without gasket. Engine block without gasket.
11-21-2021, 10:29 PM | #6 |
By the way I just realized I was wrong when I said that my gasket came with my gasket set .
It actually came my pump. My gasket set didn't come with an oil pump gasket for some reason.
11-30-2021, 12:40 AM | #7 |
So back to my original question: what material should I use to make my own gasket?
11-30-2021, 07:11 PM | #8 |
Moderator
Simple...
Take the new gasket that appears to have an incorrect cutout and use a digital caliper to measure the thickness. Should be around 0.6 to 0.8 mm. Most auto parts outlets sell various thicknesses of gasket paper. Do not use cork !!!!!!
01-08-2022, 01:29 PM | #9 |
Made my own gasket. Thanks guys.
