Old 10-17-2020, 11:25 PM   #1
P7M89MM
P7M89MM's Avatar
71 C10 2wd Center Bore
Can someone confirm the correct center bore for my truck? I thought it was 77.8mm. Tried a 1/8” spacer with 3.060 hole and it was too tight. Called Discount Tire and they’re telling me it’s 78.1mm. Maybe I should just solve my issue by tubbing the rear! Thanks!
71 Cheyenne LWB - RideTech Air, zz502, 20" Torq Thrusts
16 Sierra - Leveled, 33" Duratracs, Method Race Wheels, GMPP Intake, Borla Exhaust
15 4Runner - Icon Coilovers, 33" Duratracs, Pro Comp Wheels, NFABs
91 Malibu Skier - 5.7 Merc, Perfect Pass, Acme Prop
P7M89MM is offline   Reply With Quote
Old 10-18-2020, 01:35 AM   #2
kwmech
Re: 71 C10 2wd Center Bore
Huh? Whaaaat?
kwmech is online now   Reply With Quote
Old 10-18-2020, 01:42 AM   #3
P7M89MM
P7M89MM's Avatar
Originally Posted by kwmech View Post
Huh? Whaaaat?
Wheel center bore for hub centric spacers/wheels.
Old 10-18-2020, 08:15 AM   #4
geezer#99
geezer#99's Avatar
An 1/8 inch spacer doesn’t need to be hub centric.
Can be a little loose.
You guys need to learn metric.
Old 10-18-2020, 09:36 AM   #5
Ol Blue K20
truck of four colors!
Ol Blue K20's Avatar
What's metric? All my measuring devices are inches.
Dale
XNGH ECV Sam Brannan 1004
Ol Blue K20 is online now   Reply With Quote
Old 10-18-2020, 06:53 PM   #6
P7M89MM
P7M89MM's Avatar
Went and got a new battery for my digital calipers. Apparently my hub is not very cylindrical. I got readings anywhere from 77.4 to 78.04. I suppose I should error on the large size and go with a 78.1, if I can even find one.
Old 10-18-2020, 07:14 PM   #7
Ol Blue K20
I didn't think these were hubcentric. I learn something new every day.
Dale
Old 10-18-2020, 07:16 PM   #8
bigmac73
bigmac73's Avatar
I just put on new 20incher AR's and needed no spacer. the hub hole for the wheel was 3.083 or 78.30mm
i just cleaned up the hubs with a paper flapper wheel before i tried to measure them
measure the inside of your brake drum center hole if that fits then the bore needs to be close to that.
Mike
72 C-10 Cheyenne PS/PB/Tilt/Tach/Rear slider/
385HP/405TQ Vortec 355 /TH350 2200RPM Stall
MSD Ignition/Holley 650 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-18-2020, 07:21 PM   #9
P7M89MM
P7M89MM's Avatar
Thanks. Wheels and tires fit great with the static drop. With the conversion to trailing arms and bags I get minor rubbing on the inside left rear wheel well when taking left hand corners. Figured I’d try this route before having the wells tubbed ��
Old 10-18-2020, 07:52 PM   #10
bigmac73
bigmac73's Avatar
i have not gotten mine on the road yet. I went with a 275/55 -20 with stock height all the way around and hopefully i will not have any problems in the front
Mike
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
