01-20-2022, 12:53 PM | #1 |
Andy
seat lowering brackets
For those of you that have installed seat lowering brackets, were you able to retain the gas tank in the factory location, or is it mandatory to relocate the tank? I don't see this information posted on Brother's site or the Full custom fab site. I assume these are currently the only mass produced options for lowering the seat? My line of sight is too high through the windshield and I will be doing a conversion from auto to manual so i want as much room and to be as comfortable as possible driving my truck. I want to be able to daily drive it or take it on trips.
https://full-custom-fabrication.squa...rue&cst=custom https://www.brotherstrucks.com/1967-...tinfo/LSB6772/
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi 1969 CST/10 383|Aisin AR5 5 speed 1972 K5 350|Turbo 350 4x4 2005 Duramax 2500HD 4x4 |
01-20-2022, 01:01 PM | #2 |
Re: seat lowering brackets
I just installed the FCF in my 68 this winter. Factory tank is in place without an issue.
I have not driven it yet so I can't say if I like it or not. Currently pushing the steering wheel ahead by collapsing the column an inch.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
01-20-2022, 01:12 PM | #3 |
I was looking at the brackets, but decided that lowering the seat with a non-tilt column would put the steering wheel too high. Also, if you're taller than 6ft or so, your knees would be up higher. I'd want to try before buying.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
01-20-2022, 01:26 PM | #4 | |
Also, if you have a full-size 3-3/4" column-mount tach, it may have to go. I found an AutoGage #2300 that is approximately 3/4" less deep than the SunPro tach I had on the truck for 30 years. The old tach was no longer accurate, so it had to go anyway!
01-20-2022, 01:55 PM | #5 | |
01-20-2022, 03:05 PM | #6 |
Ha! Glad to see I wasn't the only one to do that!
My switch may not be broken, but it's probably 53 years old, so I bought a new one.
01-20-2022, 03:14 PM | #7 |
While the shorty tilt is much nicer than the stock column I didnt have a problem with the stock column with the lowering brackets drove it for 2 years before I got the new column
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
01-21-2022, 09:40 AM | #8 |
Andy
Thanks for the feedback everyone.
01-21-2022, 02:13 PM | #9 | |
01-21-2022, 04:30 PM | #10 |
I’m 6’3 and the FCF brackets put me in a much better driving position (mine is a manual with stock column and everything inside in stock location). I didn’t like the idea about only using half of the original bolts to mount the seat so I actually bought 2 sets of these and installed them 2 on each side so all the original bolt locations are used.
01-21-2022, 04:45 PM | #11 | |
