09-14-2016, 10:41 AM | #1 |
14 bolt help
I'm redoing my suspension on my 14 bolt and have to get new spring plates for the rear. It is a dually axle so it takes the plates on the bottom. Anyone know if anyone remakes these? I had a set to go on top but can't use less than a 3" block to clear and don't want to lift it. Tube diameter is 3-3/8" if I remember right...
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
09-14-2016, 11:24 AM | #2 |
Re: 14 bolt help
Lots of places. Most anywhere that carries off road fab parts should have them. Here are some from Ruff Stuff. http://www.ruffstuffspecialties.com/...UB-PLATES.html
You might also try Barnes 4wd. http://www.barnes4wd.com/U-Bolts-U-B...ates_c_37.html |
09-14-2016, 03:30 PM | #3 |
Re: 14 bolt help
Afraid those song have it. If I had a SRW THEY WOuld work. Let me try and find a picture.
09-14-2016, 10:27 PM | #4 |
Re: 14 bolt help
You may have to buy a flip kit. http://www.offroaddesign.com/catalog/uboltreversal.htm
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14, |
09-14-2016, 11:57 PM | #5 |
Re: 14 bolt help
Stengal Bros. Inc.
1105 Sumner Ave. Whitehall PA 18052 610- 433-3149 U Bolts PN # 361-413 x 2 sets Square bend 5/8 × 2.56 x 12.6 grade 8 23 bucks a pair x 2 Bottom plate PN # M1023 x 2 plates 17.95 per plate x 2 plates They come with washers and nuts I just purchased these exact ones for my 1986 K30 3+3 Dually " Cab and Chassis 14 Bolt " FYI - I purchased the ubolt flip kit from ORD and the plates were too wide to fit my C&C 14 Bolt rear " they hit the brake backing plate ", thus my sourcing stock replacements from Stengal Bros.
TecRsq _____________ 1986 Chevy K30 3+3, 454, SM465, NP205, D60 , 14 Bolt, CM Industries SS Flatbed, ORD 6" suspension, 9.00 x 16 Michelin XML'S |
09-15-2016, 11:29 AM | #6 |
Re: 14 bolt help
Tecrsq thank you. Since you redone your rear end, how did you do your brakes on the rear? My leaf springs are above my bleeder screws.
09-15-2016, 05:47 PM | #7 |
Re: 14 bolt help
My truck was purchased from a Fire Dept and only had 34,000 miles on it, as a FD vehicle it had regular maintenance. The rear brakes were fine upon inspection and I haven't done anything to them as it all looked freshly replaced.
Also I'm looking at the Ruff Stuff brackets and a rear disk application for my truck, to replace the drum setup.
09-16-2016, 10:42 AM | #8 |
Re: 14 bolt help
I want to do rear disks but is too expensive atm and my drums and shoes are in alright enough shape still. When they need replacing I will probably go disks... I'll figure something out.
Tags |
14 bolt, axle help, spring plate |
