Old 08-26-2020, 08:43 PM   #426
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Too much bling on the motor...yes, they are left over parts, but one has to do what they gotta do...stay tuned.
fishnixon is offline   Reply With Quote
Old 09-05-2020, 02:50 PM   #427
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
That’s better!
Old 09-07-2020, 12:39 AM   #428
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I worked on a problem with my steering today. The mechanism was hitting the leaf springs on a hard turn. The power steering sector was off of my ‘71 K20.
Old 09-07-2020, 12:49 AM   #429
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I went back to the donor truck (Blue Beast), and made the manual steering sector work on Dolly. No power steering, but full turning will happen.
Old 09-20-2020, 08:12 PM   #430
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
My son, Trevor, pressure washing the bottom of the cab. Finley is always in on the action. I am going to undercoat the cab. Repairs to the cab will be done later. So, here’s a before and after...
The fall colors in Northern Minnesota are busting out. I love how things are turning red...
Old 09-20-2020, 08:20 PM   #431
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Also worked on removing a leaky pinion seal on the rear end. There are no leaks at the third member that I just swapped. After applying the heat wrench and using a 3 foot cheater pipe, I got things apart. Off to the parts store tomorrow.
Old 09-20-2020, 09:27 PM   #432
Getter-Done
Getter-Done's Avatar
Re: Dumptruck Dolly
Finley is a Golden?
Oh wait the focus is on the truck
Finley is waiting for a ride
Nice progress
84 Chevy K-20
Old 09-20-2020, 10:45 PM   #433
rustytruck50
rustytruck50's Avatar
Re: Dumptruck Dolly
Looking great!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 09-20-2020, 11:53 PM   #434
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Originally Posted by Getter-Done View Post
Finley is a Golden?
Nice progress
IMO...there’s nothing like a golden. If you’ll allow me to brag just a little, his great great grandfather was the golden on Homeward Bound. His father is a “points champion”...but Finn is more than that to me...he’s my buddy.
Progress is happening...
Old 09-20-2020, 11:54 PM   #435
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Originally Posted by rustytruck50 View Post
Looking great!
Thank you!
Old 09-21-2020, 07:11 AM   #436
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Dumptruck Dolly
Some nice progress on the cab. Finely is a fine looking dog.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 09-22-2020, 12:57 AM   #437
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Thank you...
Old 09-22-2020, 09:09 PM   #438
Getter-Done
Re: Dumptruck Dolly
Good to see your truck coming Together
Here is my Golden.
The Disney Movie/ That's Awesome
How Old is your Golden?
Then back to the Truck
84 Chevy K-20
Old 09-24-2020, 01:23 AM   #439
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Here is my Golden.
Attachment 2050161
Beatiful golden...what’s his/her name?
Finn is 2 years old...
Hope to finish up the pinion seal Friday. Then I’ll line up the two piece driveshaft and locate the crossmember and carrier bearing...then I think I can put the cab back on...
Old 10-17-2020, 05:44 PM   #440
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Had problems with the threads on the pinion...I had to buy a dye and redo the threads...kind of a long delay. Got it fixed and put the driveshaft in from the K20 donor. Matching gears and connecting the front to the back feels good.
Old 10-18-2020, 07:14 AM   #441
Ol Blue K20
Re: Dumptruck Dolly
It looks pretty good too! It's going to be driving in no time.......
Dale
Old 10-18-2020, 09:35 PM   #442
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Thanks...I can hardly wait to fire it up. It’ll be a little bit yet, as there are a few things competing for my time.
Old 10-18-2020, 09:39 PM   #443
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
New cab rubber mounts, bolts etc...the cab has returned home!
Old 12-01-2020, 10:15 PM   #444
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I’m back...the accumulation of smaller items is getting Dolly closer. The fan, accelerator rod linkage, alternator brackets with a new alternator, power steering pump and steering box with new belts, are all back on.
I was able to figure out why “at first” the power steering box didn’t work...it was a problem with my front tire alignment. All that fiddling around created a waste of time, but with a bonus of gaining a little more knowledge as a positive result.
Old 12-01-2020, 10:29 PM   #445
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
The 4 speed Z bar clutch mechanism was a little problem initially. I couldn’t connect the tube that goes between the block and the frame mounting bracket because my Doug Thorley Header wouldn’t allow for the angle I needed. I wasn’t going to take the header off for the 5th time! My choices were to remove the motor mount bolt and jack up the motor or to cut the rivets off the bracket on the frame, assemble the Z bar and bolt the bracket back down. I chose the latter and it wasn’t too bad of a fix. That’s done!
Old 12-02-2020, 05:02 AM   #446
Ol Blue K20
Re: Dumptruck Dolly
I'm glad that you're still at it. It's coming along nicely.
Dale
Old 12-04-2020, 08:32 AM   #447
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I had to locate another pair of valve covers as the ones I had painted were too tall for the brackets of the alternator setup I had. One of my parts trucks came through. Now I “have” to get another set of 327 stickers.
Old 12-05-2020, 10:27 PM   #448
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Time to put the fuel tank in...I have about 1/3 of fuel in the tank. This tab was a formidable foe as I tried to get the tank over it while the gas filler was in position. Geez...
Old 12-05-2020, 10:30 PM   #449
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
New sending unit for V8 put in as well as larger line which came from my parts truck, going through the floor.
Old 12-05-2020, 10:34 PM   #450
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Fuel line from a V8 (now the smaller 6 cylinder fuel line is in the parts bin)...hooked up a 90 degree 3/8 inch line on the front, and added some bling for the fuel line hook up under the cab as it was all I had left in 3/8 inch.
