03-07-2012, 09:57 PM | #1 |
auxillary battery tray
If you do not mind moving your washer bottle you can install one of these. If you use a continuous solenoid that turns on with the key ON, it will be a functioning auxillary battery.
03-09-2012, 12:01 AM | #2 |
Re: auxillary battery tray
That looks like a nice kit....who makes it?
I bought an aftermarket tray previously but it seems to becoming more expensive. This time around I made my own by cutting up an old, passenger side original tray and retrofitting it. But, I like this set up...looks good.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
03-09-2012, 10:33 AM | #3 |
I added one to my 72K5. I got mine long time ago from an online sale. Can't recal what it was pulled from but at one point in 67-72 GM did install a Driverside batt tray. That kit looks good ~ drivers side is just a mirror image of the pass side tray Oh and I use www.hellroaring.com Iso/Combiner to keep both batts charged and the second batt is 100% backup or I can combine the batt power when winching heavy loads. Not cheep but awesome product!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
03-09-2012, 11:10 PM | #4 |
I make the side brackets and purchase the tray.
03-10-2012, 09:38 AM | #5 |
Also, the radiator does not have to be removed to mount the supports as it bolts or metal screws to the front radiator support. One or 2 holes need to be drilled but it also uses an existing hole for lineup. Attached is a pic of the solenoid setup. positive battery cable goes to the solenoid connection seen. White wire is from the ignition ON. 10 gauge black on far side goes to the main battery --- fused.
03-10-2012, 09:48 AM | #6 |
Shown where I found the best place to remount the washer bottle in my k10.
12-03-2022, 02:21 AM | #7 |
I know this is an old thread, but really am hoping you have the measurements for the side panels on the battery tray?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
12-03-2022, 04:24 AM | #8 |
Measurements or a template? I may have a pair without the tray. Rockauto used to have the trays for a 67-72 c/k10.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
12-03-2022, 05:48 AM | #9 |
Not trying to stifle OP's brackets. While hard to find OEM aux battery trays can still be found. Just post a WTB in parts. IMO better options for an aux battery than a relay/solenoid. Dual output alternator or an isolator.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
12-03-2022, 11:46 AM | #10 |
Mostly measurements. There was an old thread on it, but cannot seem to find it
12-08-2022, 10:55 AM | #11 |
You can buy one already built and painted. A quick bolt in.
https://www.holley.com/products/exte.../parts/BBA72AX j
White K20 |
