06-14-2021, 02:51 PM | #1 |
upper molding
My upper molding was about to fall off of my 71 C10 due to poor adhesive clips. So I got a set of push in and bolt on clips. When I looked at the trim before removing I noticed that it was low at the rear of the bed. I was planning to correct it. Unfortunately, there are factory holes directly behind this trim! It is like this on both sides. It is 1" lower at the rear of the bed vs the front. Of course now I notice it every time I look at the truck. I would think the factory meant for the trim to be a straight line from front fender to back of bed? Mine has a noticeable angle beginning at the cab/bed junction. How is this trim supposed to look? TIA
PS> My body lines all line up cab to bed. |
06-14-2021, 03:56 PM | #2 |
Re: upper molding
The upper trim on the bed drops down to the rear. It should be parallel with the body line right above it, NOT parallel with the top of the bed. You can see it easily in the direct side shot...
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
06-16-2021, 10:29 AM | #3 |
Proprietor of Dale's Corner
Re: upper molding
It's supposed to droop like that. I know it seems weird, but it's normal.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-16-2021, 01:11 PM | #4 |
Re: upper molding
That is good to know. I pulled some crooked trim off my truck as the door and fender were replaced years ago and also pulled the bed trim off thinking it was crooked as well!
It appears that my bed trim is in the correct spot after looking at that photo.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
06-17-2021, 02:11 PM | #5 |
Re: upper molding
Just looked at the hole in the bed side for the upper moldings and you guys are right it does appear to slope down at the rear. Never noticed that before.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
