06-08-2021, 02:36 PM | #1 |
Replacing seal on steering gear
Have you guys done this while the steering gear is on the truck? Or, do you guys take it off?
It is probably a little difficult to get at it while laying on a creeper.
1963 C20, small window, long bed 292, 4-speed |
06-08-2021, 02:42 PM | #2 | |
Re: Replacing seal on steering gear
I take them off.
06-08-2021, 05:07 PM | #3 |
Can anyone tell me which seal goes in first? One seal is thicker than the other.
06-08-2021, 07:36 PM | #4 |
This is the guide I used, from Tx Firefighter
http://67-72chevytrucks.com/vboard//...d.php?t=619634 The order from outside in is snap ring, flat washer, thick seal, washer, thin seal. |
06-08-2021, 09:38 PM | #5 |
I came to the conclusion that my input shaft is leaking, not the pitman arm shaft. I read in this post below, it is possible to replace the input shaft seal without disassembling the entire gear. Is this true?
http://67-72chevytrucks.com/vboard/s...d.php?t=747396
06-08-2021, 09:55 PM | #6 |
The procedure for replacing the seals without disassembling the entire gear is in the guide from Tx Firefighter that I gave the link to.
06-09-2021, 08:12 AM | #7 |
The most common leak point is the o-ring on the adjuster plug and not the input seal.
While I knew guys that would replace that o-ring on the truck, I always felt better doing it on the bench. There's a few important steps that have to be done just right for the box to work properly again.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
06-27-2021, 11:53 PM | #8 |
I removed the steering gear since I could tell it was leaking at the input shaft seal. Hopefully, the seal kit I get will work.
