Old 12-28-2021, 04:26 PM   #1
Chevy Fleetside
Chevy Fleetside's Avatar
Great Ball Joint won't stay in lower control arm
I just changed my lower ball joints and now the ball joint will not stay pressed in. It just falls out. Anyone know the fix for this? These are Moog Ball Joints also.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-28-2021, 05:28 PM   #2
ChadW
Re: Great Ball Joint won't stay in lower control arm
sounds like the wrong ball joint for the year of spindle used...
ChadW is offline   Reply With Quote
Old 12-28-2021, 05:44 PM   #3
Chevy Fleetside
Its the right one. It falls out of the lower control arm. The ball joint seats in the spindle just fine. The old one I took out came out kind of easy and now it's not even a tight fit but it is still snug.
Old 12-28-2021, 06:10 PM   #4
Chevy Fleetside
Well looks like I will just have to tack weld them in until I can find new lower arms. Anyone have a source for new lower control arms for a 75 chevy c10
Old 12-28-2021, 07:37 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
I think Moog makes a Problem Solver balljoint that is slightly oversized for the control arm hole.
Keith
Convert to disc brakes.
Old 12-28-2021, 08:40 PM   #6
vin63
It's Better With Nitro
vin63's Avatar
I think the balljoint housing seat is smaller in diameter for a '65 lower control arm than the balljoint for a '75 lower control arm. If you're trying to press in a 65 balljoint into a 75 control arm, it will most likely fall out like you're expriencing.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-28-2021, 10:53 PM   #7
Chevy Fleetside
No.. I am putting in a 75 ball joint into a 75 control arm.
Old 12-29-2021, 01:09 AM   #8
SkinnyG
SkinnyG's Avatar
Problem Solver should fix that. Failing that, you can "shrink" the hole down by heating the ring up with a torch and letting it cool.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 12-29-2021, 09:06 AM   #9
Chevy Fleetside
I will try thait.. Thanks,
Old 12-29-2021, 03:22 PM   #10
SCOTI
SCOTI's Avatar
As mentioned.... The Moog Problem Solver series of BJ's are supposed be slightly larger OD just for issues like this & the 'old-school' remedy is some tack welds to keep the joint housing in place.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-29-2021, 03:27 PM   #11
Chevy Fleetside
I have looked and have not found any problem solver ball joints. If anyone has a part # that would make it a lot easier. This would have to be for a 1975 year model truck.
Old 12-29-2021, 03:56 PM   #12
SkinnyG
SkinnyG's Avatar
https://www.rockauto.com/en/moreinfo...=10070&jsn=467
Old 12-29-2021, 05:21 PM   #13
Chevy Fleetside
That was the ball joint I was using. I was able to heat it and let it shrink around the ball joint. All is tight now. Who says you can't teach an old dog a new trick.
Old 12-31-2021, 02:30 AM   #14
burnin oil
I think you are supposed to heat the control arm and then install the joint. I would definatly over grease it a few times to make sure there is no broken down grease in there.
burnin oil is offline   Reply With Quote
Old 12-31-2021, 01:16 PM   #15
Chevy Fleetside
I first heated the control arm and then put the ball joint in as it cooled and sealed around it. I didn't heat up the ball joint. And also it took 23 pumps of grease to fill up the upper ball joint and about 13 pumps for the lower.
Old 12-31-2021, 05:11 PM   #16
SkinnyG
SkinnyG's Avatar
Heat Shrinking is one of the seven wonders of the universe.
Old 01-23-2022, 07:30 PM   #17
dracko
dracko's Avatar
I ran into the same exact issue with the '83 crossmember I swapped into my '64. Glad to hear i'm not the only one to run into such a strange issue, haha. Also, used MOOG problem solvers and the problem wasn't solved, thought maybe I had wrong parts so double checked numbers til my brain hurt.
Ended up tack welding them to the lower control arm, once the spring is installed they sure as hell aren't falling out, lol. Been in there for a couple years now with no issue.
Edit: just saw the heat shrinking method worked, great idea! I'll try that next time.....although hopefully there isnt a next time;
dracko is offline   Reply With Quote
