07-02-2022, 12:05 PM | #1 |
Rotor replacement on ECE disc conversion
I’m running a 6 lug rotor from ECE and I want to change to 5 lug and just wondering which rotor I need ? Would a stock 5x5 for a square body work or do I need a special rotor ? Thanks in advance.
Kirk Myers 68 chevy swb owned since 87, under the knife 71 skylark 9.20's @ 76mph 1/8 mile |
07-02-2022, 12:53 PM | #2 |
Re: Rotor replacement on ECE disc conversion
You should be ok with the stock squarebody 1.25" rotor. Basically just get a rotor for a 75 square
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
07-02-2022, 01:53 PM | #3 |
Thanks for the quick reply.
