Old 10-21-2022, 05:14 PM   #226
marc55
marc55's Avatar
Re: My 55 Chevy 4X4
Put the exhaust together. Going with flowmaster delta 40s. Wanted to stainless steel but my TIG skills are not there yet.
marc55 is offline   Reply With Quote
Old 10-24-2022, 04:12 PM   #227
dsraven
Re: My 55 Chevy 4X4
for anybody lurking, you can also weld stainless with an arc welder. I just did a repair on the wifes audi exhaust with my old arc welder. the exhaust pipes are from 2001. it turned out great. clean the metal well first, don't use a regular steel wire brush to do that.
Old 11-24-2022, 12:55 PM   #228
marc55
marc55's Avatar
Re: My 55 Chevy 4X4
Have the gas tank ready to install and working on the radiator hoses.
Old 11-25-2022, 11:22 PM   #229
G&R's57GMC
G&R's57GMC's Avatar
Re: My 55 Chevy 4X4
Great project .
Congratulations on your marriage, I was married on Halloween also .
I’ve got a genuine factory installed NAPCO ‘57 GMC that’s been finished for decades . Soon it will go under the wrench and become a two wheel drive air ride 5.3 automatic Currie 9” .
It also will have power windows ,Altman latches a/c etc. The new chassis was done in 2010 then other projects took over the shop .
Did you use Bear Claw or Altman door latches ?
Looking forward to your solution to getting Electric into the doors, I’m thinking contacts also .
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 11-27-2022, 02:35 PM   #230
marc55
marc55's Avatar
Re: My 55 Chevy 4X4
The kit was an Altman kit. I need to do more adjustment on the doors. right now they latch but after I get the door gaps where I want them I might not have the adjustment I need for the striker. The power windows are Nu-relic and they went in nice. Just a little trimming on an inner brace for motor clearance. I rather just use contactors instead of the sliding loom style for door power but I have some folding steps I want to install and not sure what they need to switch them to work.
Old 03-04-2023, 01:13 PM   #231
marc55
marc55's Avatar
Re: My 55 Chevy 4X4
Got a BP automotive harness and started wiring the engine bay.
Old 03-04-2023, 01:19 PM   #232
marc55
marc55's Avatar
Re: My 55 Chevy 4X4
The engine started up just fine and I let is run for about 30 seconds. The next day I had a small leak from the top of the gas tank. I was never happy with the mounting bracket I made for the tank. Verry hard to remove the tank. So I decided to redo the bracket so it can be removed easier. I am also going to add hard lines to extend past the top of the tank so I can disconnect the flex lines without having to lower the tank.
Old 04-09-2023, 11:34 AM   #233
marc55
marc55's Avatar
Re: My 55 Chevy 4X4
I fixed the gas leak issue. Got my air intake routed and plumbed the power steering.
Old 04-09-2023, 11:45 AM   #234
marc55
marc55's Avatar
Re: My 55 Chevy 4X4
Added all the fluids and ran the engine up to temp. No leaks and the fan turned on at 190 degrees. So now I can start the wiring. Doing the ignition first. Everything but the starter is going through a 200 amp megafuse. Then I am using a button that controls a 200 amp relay that send power to an engine bay and dashboard power distribution block. The dash power is also protected by a 150 amp breaker. I figure the relay is a convenient way to disconnect the battery and prevent a draw when sitting.
Old 11-22-2023, 06:14 PM   #235
marc55
marc55's Avatar
Re: My 55 Chevy 4X4
Getting closer. Front end is on. Lights are done. Shocks installed. The rear was a little squatted so I removed the 2" lift blocks and installed a 4" shackle reverse kit. I also found some bucket seat that work better than the bench seat I had and I bough a dakoda digital dash.
Old 11-23-2023, 08:28 AM   #236
rgunlock
rgunlock's Avatar
Re: My 55 Chevy 4X4
Truck is looking really good... and pretty much done! What is left to do?
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 11-23-2023, 04:16 PM   #237
marc55
marc55's Avatar
Re: My 55 Chevy 4X4
I am registered and will start doing some shake down runs in March when the weather gets better. I am working on the interior. Going to put the sound deadener in, picking carpet colors, and designing a center console, adding 3 point seat belts, and a heater. Looking to do a tannish Carmel with black. Down the road I will have the seats reupholstered to match. It feels good to be done. I have 2 more projects on deck. a 38 ford rat rod that I started when the truck was in paint jail and a 68 Firebird I bought over 30 years ago with my lawn mower money when I was 15. I want the 38 moving at the end of summer and the 68 on the road in 3 years.
