05-23-2023, 01:03 PM | #1 |
Crank Pulley to Center Link Clearance
Looking for some help on a clearance measurement. With a stock 350 SBC, how much clearance is there from the steering center link to the bottom of the crank pulley? I raised my steering components with a pancaked crossmember and I think it's going to be close now.
My 1970 C10 ChassisFab LWB to SWB Build Thread |
05-23-2023, 02:06 PM | #2 |
Re: Crank Pulley to Center Link Clearance
you can always go with a smaller damper if needed
05-24-2023, 11:04 AM | #3 |
My ‘70, with a 350SBC, in the original (307) position, has approx. 1-1/4” clearance to the front of the oil pan. My 8” damper is forward of the center link. Hope this helps
Posted via Mobile Device |
05-24-2023, 12:44 PM | #4 |
Thanks for this. I think I found a solution to move the block back just enough to clear the pan and balancer. These are adjustable engine block mounting plates.
