![]() Join Date: Feb 2001
Mirror Mirror on the wall ... Dimension help 70-71
I bought my 70C10 back in 01... in the mean time I have been buying spare parts. Way to many spare parts
My truck is 99% finished and I don’t need 8 sets of mirrors plus a bunch of spare parts that I am starting to go through. Question: What are the difference between the 70 and 71 below eye line mirror? Thanks Yes - these mirrors will be going up for sale soon.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Mirror Mirror on the wall ... Dimension help 70-71
68 thru 71 are all same..... 72 has a different (small) upper arm. I believe the lower arms on 72 *may* be shorter also.
Pic of 72-only style DG4 mirror:
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 08-05-2022 at 01:06 PM. |
![]() Join Date: Oct 2009
in post 1, pic 2: the bottom 2 sets of lower legs are 72 (lower attach points attach above upper trim), the rest of the lower legs shown appear to be pre-72 (lower attach points attach below upper trim).
Mirror heads are identical for all below eyeline mirrors 69-72 (they eventually changed in the square years). I think the uppermost mirror head in pic #2 is not an original (not the different attach point webbing/stiffeners) - but not certain from the pic. Note that the mirror head attach point should be centered vertically on the mirror - some aftermarket mirrors are off-center vertically (I'd look closely at 3rd mirror in middle row of 2nd pic in post 1). Also take close note of the different upper attach leg flanges/angles where they connect to the door - stocker's shows the correct for 72, somewhat flat attach flange . Most of your pre-72 stuff shows the angled down version (to further identify them as pre-72, in addition to the long lower legs). I'd look closely at the upper leg of the left 72 mirror in post 1, pic 2 - that upper leg appears to not be original (flat vice round). Last edited by jocko; 08-05-2022 at 02:46 PM. |
#4 | |
![]() Join Date: Jan 2013
Could you please back away and post a picture of that whole truck? The close-up is pretty nice...
![]() Join Date: May 2010
Just to add some nitpicking comments...and confusion... to something that probably makes no difference at all.
I also noticed while junk yarding that there are apparently 2 slightly different leg styles and different length brackets from the cab to the legs on the pre-'72 version. What I wondered is if the later style has the slightly sharper bend at the foot of the legs, and the shorter bracket (5-1/4 in. vs 6-7/8 in.) to better accommodate the upper cab molding when ordered present. The attachment points on the doors are identical. I now have those with the slight bend on my truck. My '69 (Dec. '68 build) also had DG4s with offset mirror heads. Comparison pics. First 2 are my originals. Third is the one with sharper bend and shorter top arm.
Jim Last edited by FirstOwner69; 08-05-2022 at 10:59 PM. |
Oops. Duplicate post
Jim |
Interested in drivers side for 1971 Thanks, Dan
These will be put up for sale in the FS section soon.
Thread Tools | |
Display Modes | |
