Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-27-2021, 12:02 AM   #401
Tuff Gong
Tuff Gong's Avatar
Re: 1972 Medium Blue Highlander Blazer Resto
Glad to see you are back on the road
Tuff Gong is offline   Reply With Quote
Old 01-27-2021, 08:55 AM   #402
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks Brian. With the CA emissions equipment it added another layer of hassle but it was buttoned up well.
Old 01-30-2021, 01:46 AM   #403
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Geeezus how'd I miss this thread? Yeah Pete, it's not unusual I miss the obvious, source to your Blazer in your sig. all along. Unbelievable what you did with that Blazer, cream of the crop.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-30-2021, 09:20 AM   #404
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Tony thank you!
Old 02-01-2021, 07:16 AM   #405
LT7A
I've read through both of your build threads now, making some notes. I'm more of an OEM guy than an NOS guy, but I can certainly appreciate the effort and the expense. A couple of beautiful trucks and glad to see that you get them out and about, even on dirt. I'm curious how you like the performance of your engine after rebuilding it to stock spec but with a RV or towing cam that is a roller. I like that idea and wondered how it worked for you.
Old 02-01-2021, 08:46 AM   #406
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thank you! The motor works well for what I use it for. I haven’t had many days behind the wheel yet since the top end was redone. The idle in the Blazer could be a tad smoother. In my opinion, the cam the builder selected is better suited for more of a street car application than my style of driving. If I were to select a cam I’d go with MC22135 rather than MC22238, which is what I have: https://enginepro.com/downloads/newd..._CamShafts.pdf
Old 02-01-2021, 03:40 PM   #407
LT7A
Interesting on the cam specs. It looks like you may be have what they would call a stage two or three cam. A lot of people like the lopey idle and I get that, but I wouldn't want to sacrifice torque for the sound. A smooth idle is fine by me. What was interesting on that sheet was how they wanted their stage one cams to be for lower compression engines. If I was doing a rebuild I would probably shoot for about 10 to 1. My trucks tend to do all their driving in off-idle to 2000 rpm. Probably 2,500 for merging on the freeway, but 3,000 is winding it out for me, haha. Thanks for the info, I will be saving that for when it comes time to rebuild and go with a roller cam.
Old 06-07-2021, 07:58 PM   #408
68ls1
68ls1's Avatar
Great build, will certainly help me on mine. Finally due to arrive in Oz next week.
Couple of questions, did you install the steering stabilizer and do you have the build/spec sheet for the Alcan springs?
68ls1 is offline   Reply With Quote
Old 06-08-2021, 07:20 AM   #409
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thank you. It’s running great now. I need to pull the top yet for summer driving.
Congrats! Hope that it arrives swiftly and safely. Please share photos when possible.
Yes, I did reinstall the steering stabilizer, which is a Delco Pleasurizer unit, using original hardware. The front axles for the 72 model year have a bracket affixed to the LH side to accommodate the outboard end of the stabilizer and the inboard end affixes by way of a clamp on the tie rod.
Old 06-08-2021, 09:38 PM   #410
tim71
tim71's Avatar
First off....your Blazer is stunning. I am curious if you would share your knowledge about the Highlander seats. I've read through your build a few times but missed where you sourced your seat covers. Is there a vender that sells Highlander seat covers, or do they have to be custom made? Where can the Highlander plaid fabric be purchased? Is the parchment vinyl readily available?
My 72 Blazer seats are covered in nonoriginal black vinyl, so I'm pretty much starting from scratch. PO even covered the back of the bucket seat with the black vinyl. I haven't tore the seats apart yet, but I can peek in and see the original bucket seat backs are there. Unfortunately, a PO painted everything black that was originally parchment (visors, door panels, bucket seat backs).
My Blazer was built in St Louis and it has the white step up plate.
Thanks, Tim
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
tim71 is offline   Reply With Quote
Old 06-08-2021, 10:18 PM   #411
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Hi Tim - I’m glad you got that Blazer. Good buy.
Thanks for the good words. Dealing with the upholstery was a lengthy nightmare.
My covers were made to order by Truck World (Larry Nease) who essentially wholesales to dealers he works with. There’s a member here that’s successful at keeping Larry focused. Send me a PM and I’ll share the details. The member that I used at the time is no longer in the business.
There is a vendor in Texas that was advertising plaid front bucket covers. I’m uncertain where these were/are made but I’ve yet to see examples that have the pattern correctly aligned. There’s a consistent pattern of alignment with the front bucket covers but that’s not the case for the rear from what I’ve observed. It takes more yards of fabric to achieve the correct alignment between the front covers.
SMS fabric offers repro plaid fabric and the vinyl can be had. The rub is the rear seat cover, which has embossed scrolling. Larry is able to get correctly embossed vinyl to assemble the rear seat cover. Also, make sure that the rear seat receives the correct pattern on the vinyl across the back of the seat (it’s ribbed).
Hope this is helpful. If possible start a build thread for your Blazer, I’d like to follow.
Old 08-05-2021, 11:25 PM   #412
tim71
tim71's Avatar
Curious if you might have a photo of your steering damper installed. My 71 K1500 didn't utilize a steering damper so I can't reference it. I took a lot of photos when I tore down the Blazer but somehow missed a good shot of the damper. I knew that I was going to replace damper, so I discarded the damper cylinder that was on the Blazer.
Even a photo of uninstalled damper would help. Going thru your build, I did find a photo referencing a measurement for the damper, but not a full view of damper.
Thanks, Tim
Old 08-06-2021, 07:26 AM   #413
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Hi Tim - lmk if this helps. I’ve got loose examples too.
Old 08-06-2021, 03:08 PM   #414
tim71
tim71's Avatar
Yes, that photo was helpful. Thanks, much appreciated. Tim
Old 09-24-2021, 11:47 PM   #415
jmking9
jmking9's Avatar
If you don't mind me asking. Where did you source the 15x8 steel wheels from? Also, do you happen to remember the back spacing? I'm not having any luck finding oem wheels for my 72, so I've been looking at the ones from Cooper Restorations. They have a 4.25" bs, and I have read that 3.75" is the max to clear the tie rods. Any input would be much appreciated. Thank you!
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 09-25-2021, 09:53 AM   #416
DeadheadNM
Carpe manana
DeadheadNM's Avatar
You bet. I sourced the wheels here on the forum if I recall. The backspace on these wheels is often indicated as 4” but I’ve never measured them myself. Check with Cooper, I bet there’s a set that will work: http://67-72chevytrucks.com/vboard/s...d.php?t=751354
Old 06-27-2023, 12:50 PM   #417
tim71
tim71's Avatar
Pete, would it be possible for you to post a few photos of your hatch hinges with the hatch in the upright position? Kind of the view in post #330, but aimed up higher to include the hinges and associated gaskets and cover. Thanks, Tim
Old 06-27-2023, 08:06 PM   #418
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Do these work Tim?
Old 06-27-2023, 09:51 PM   #419
tim71
tim71's Avatar
Thanks for the photos. I’m trying to determine how the metal cover/gasket lays. The hinge goes through cover/gasket and then bolts to top. Only two ways it can attach, rounded surface facing either inward or outward .My guess is the rounded surface faces away from the top but mine doesn’t seem to screw down tightly. Based on attached photo, do you know if this is correct or do I need to turn the rounded cover over? I failed to get a good photo of this prior to tear down, plus there’s a good chance that it could have been installed incorrectly anyway.
Old 06-27-2023, 11:00 PM   #420
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Tim yours looks correct - flat face inward against the seal between the hatch and the escutcheon/bezel/plate deal. Glad to help.
Old 09-01-2023, 09:53 PM   #421
CanadianNascar
CanadianNascar's Avatar
WoW ! Incredible build and documentation, museum quality.
Our VINs are only 376 units apart!
I'm in this thread for future reference lol.
CanadianNascar is offline   Reply With Quote
Old 09-03-2023, 04:25 PM   #422
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks! That’s awesome. Thanks for comparing VINs. Wonder how many days separate our Blazers in terms of assembly? Can’t be many.
Old 09-03-2023, 04:30 PM   #423
CanadianNascar
I worked at Lear, building seats for the GM Oshawa plant for 12yrs, until the crash of 2008. Gm Oshawa would build approx 540 units per shift. They had it down to an art form though. I'm sure 300 units back then would be possible, can't be more than 2 days apart.
Old 09-03-2023, 04:49 PM   #424
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Love it. That’s incredible. As an aside, is Oshawa still online?
Old 09-03-2023, 05:23 PM   #425
CanadianNascar
Yep, 3 shifts again, they started up about 2+yrs ago. Mostly new employees, at a much lower pay.
They have the new flex line, can build light and medium duty trucks on same line, and I think cars can be also.
