Old 06-04-2022, 07:48 PM   #1
Axememan
Noisy Saginaw
Hello I rebuilt a 4spd Saginaw to replace the sm420 in my 55 Chevy pickup. It drives nice with this transmission better gearing. I’ve got a ticking noise, in or out of gear, clutch in or out , engine on or off, but not in reverse if the truck is moving it tics. What is it? My guess is reverse idler bushing. But where do I get one. Thank you Paul
Axememan is offline   Reply With Quote
Old 06-05-2022, 07:06 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Noisy Saginaw
My guess is a U-Joint.
AcampoDave is offline   Reply With Quote
Old 06-05-2022, 07:25 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
Re: Noisy Saginaw
What he said! Uni joint dried out
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 06-05-2022, 11:28 PM   #4
Axememan
Re: Noisy Saginaw
New u joints along with new drive line, ordered online USA made came with u joints with grease fittings. When together with new transmission . I can unhook the drive line and spin the tail shaft see if it makes noise. Thank you
Old 06-06-2022, 11:15 AM   #5
geezer#99
geezer#99's Avatar
Re: Noisy Saginaw
New trans and driveshaft.
Did you have to change the pinion angle or did you check it?
Could be a binding u-joint.
Old 06-06-2022, 11:26 PM   #6
Axememan
Re: Noisy Saginaw
No I did not check that. The new transmission is only 10” longer than the old one. The truck is at original ride height in the rear minus 63 yrs of sag. New drive line length is 54-1/2”, none of the angles look bad. thank you.
Old 06-06-2022, 11:32 PM   #7
geezer#99
geezer#99's Avatar
Re: Noisy Saginaw
You should check the angles though.
Another reason I thought of pinion angle is your saying no noise in reverse.
In the forward gears the pinion nose tends to rise. In reverse it drops down. When it drops down the angles could get closer to equal so no binding or noise.
