05-25-2021, 02:48 PM | #1 |
grease for those squeaky polyurethane bushings
here is a quick write up on greases for polyurethane suspension bushings. hope it helps somebody.
when installing those poly bushings think about a grease zerk along with a line up hole in the bushing to allow the grease zerk to get grease right into the contact area where the grease is needed. some stainless body washers on each end of the bushing has also worked for keeping the grease inside the bushing, for me anyway. https://www.suspension.com/blog/the-...hane-bushings/ |
05-26-2021, 08:17 AM | #2 |
Re: grease for those squeaky polyurethane bushings
good info!
05-26-2021, 10:51 AM | #3 |
Very Nice!
05-26-2021, 01:04 PM | #4 |
my fatman mustII kit instruction said the bushings were graphite infused and no grease was recommended. yeah, in 4 years the bushings were slap worn out, egg shaped and squeaked like the dickens. my truk sat a couple inches lower just from worn out bushings.
i rebuilt the front end and had some energy suspension grease laying around and threw it in there. still going strong after 4 years.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-26-2021, 03:25 PM | #5 |
I have installed energy suspension control arm bushings and other parts in a few more modern cars and trucks. I usually try to install a grease zerk and ensure there is a hole drilled to line up with that and/or a groove cut the circumference of the outside of the bushing so grease from the zerk can make it around to the hole that leads to the wear surface. I always suggest to grease the bushings at every oil change. so at least once every ten years for some guys, haha. I find the grease that comes with the bushing set is super sticky but aftermarket grease gun stuff is generally not so sticky. I suggest to grease more often in that case until the guy gets a read on how often is required. for those horeshoe shaped stabilizer bar bushings I usually try to clean the shaft really well first and lightly paint it or at least prime it, then wrap it in wide plumbing teflon tape tightly before greasing and installing. I haven't had any complaints so it must work I guess.
