Old 12-08-2016, 12:20 PM   #1
LS Nasty
LS Nasty's Avatar
Porterbuilt/headers
Been looking around for the last couple day with no real definitive answer. I'm running a version 5 Porterbuilt extreme up front with an LS1. Outside of using the Holley manifolds what actual headers will work?
1969 GMC SWB LS1 PORTERBUILT/Choppinblock
2013 F150 Platinum (Beater)
1978 F150 (Dust Collector)
Build Thread of Doom>http://67-72chevytrucks.com/vboard/s...d.php?t=650851
LS Nasty is offline   Reply With Quote
Old 12-08-2016, 12:46 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Porterbuilt/headers
Did you ask Porterbuilt? I'd start there.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 12-12-2016, 12:03 AM   #3
68c10airstream
68c10airstream's Avatar
Only one response so assuming you will be real low, long tube headers wouldn't work. About 5 years ago my ls swap ended up with sanderson shorty headers. There wasn't a lot to choose from back then. I used the stock 2001 5.3 engine mounts and removed my frame brackets so nothing was in the way. I couldn't guarantee they would clear if the frame brackets were there. My headers point back and down at about 45 degrees and end at about the back of the engine. Sanderson didn't have a truck application at the time so I opted fro 68 and newer nova with a ls. Good luck.
68c10airstream is offline   Reply With Quote
