Old 03-03-2017, 06:40 PM   #1
KyleSeal
KyleSeal's Avatar
Block hugger headers ......
Looking for examples of how anyone on here has run theirs on a 350 in a 70 C10. I will be running 3 inch pipe. Going to be a low truck so I need to see some ideas on ways to route.
I will run a mini starter.
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 03-03-2017, 07:27 PM   #2
wbc409
Re: Block hugger headers ......
If you are running a mild engine you won't really gain anything by switching to block huggers if you already have the old rams horn style manifolds. If your engine is that mild, I wouldn't use anything over 2 inch exhaust on a small block. It will actually hurt engine performance. I have a mild 454 and only use 2.5 inch dual exhaust. I am assuming you want to use block huggers for the appearance. I would get them ceramic coated, not sure what manufacturer makes the best. I have Hedman long tubes on the 454 and have had good luck with them.
wbc409 is offline   Reply With Quote
Old 03-03-2017, 08:57 PM   #3
KyleSeal
KyleSeal's Avatar
I'm not worried about engine performance, and I've actually seen data to show that 2 vs 2.5 vs 3 makes very little if any difference. I want 3 because I'll be exiting through the bed and it looks good. Ram horns in the correct angle are tough to find where I am and I got these for free.
350 v8, 70 c10, block huggers, exhaust
