08-03-2022, 08:52 PM | #1 |
Who Changed This?
Dash Pad
OK, I'm not seeing a thread dedicated to upholstery. My dash pad is pretty much toast after all these years, and having various schlock items attached to it over those years. I'm looking at the dash pad at LMC, and am curious about people's experiences with it. It would appear that it attaches over the old one, by the description. Knowing what a pain in the keister it is to get to the fasteners, attaching over the old one (somehow) would seem to be less trouble. Any thoughts?
https://www.lmctruck.com/1967-72-che...h-pad-assembly
08-03-2022, 09:19 PM | #2 |
Re: Dash Pad
I never used one of those. I did order a new complete replacement one from Southern Ky Classics for the old blue truck in my build thread. It was good quality and after the fact, I wish I had ordered a new glove box liner and some defogger vent hose. I took out the glove box door and liner, defog vent and was able to access everything short of 3 nuts under the dash. I didn''t have to pull the gauge panel, just used a various few 1/4 inch extensions. The one in the far left corner is all by feel. 2 and a half hours tops. And that was on a 100 degree day.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1971 c10 swb/1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
08-04-2022, 09:07 AM | #3 |
Re: Dash Pad
do it right, remove and replace, or recover.
I have a 67 pad available you could have recover, and then swap them out. |
08-04-2022, 10:50 AM | #4 |
low n' slo
Re: Dash Pad
i think you are reading it wrong. it looks like the same one i installed (bought mine about 8 years ago and just installed it). it wasnt a cover though, you pull the old one off and install the new one in its place. im guessing with the way its worded. they should just call it dash pad assembly.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
08-04-2022, 01:01 PM | #5 |
Who Changed This?
Re: Dash Pad
OK, reading it again (and scrolling down) I see that there is a cover and a cover assembly. The assembly is what I would want, I guess. I'm not excited about the labor for that, though.
08-04-2022, 01:27 PM | #6 |
low n' slo
Re: Dash Pad
ya...its tough to get to the corner ones for sure. i still havent fully tightened those 2 all the way. the rest are pretty simple. much easier if you pull the cluster and glove box liner
08-04-2022, 02:01 PM | #7 |
Re: Dash Pad
I got my new dash pad assembly from Classic Industries.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
08-04-2022, 04:59 PM | #8 |
Re: Dash Pad
Pretty proud of those covers compared to the whole assembly. The difference in price will buy a lot of beer for those sit back and reflect moments. You know before you go and get the BIG hammer.
08-04-2022, 05:06 PM | #9 |
Who Changed This?
Re: Dash Pad
I'm mystified by the black assembly being cheaper than the cover.
08-04-2022, 05:10 PM | #10 |
Re: Dash Pad
The OER one I got from Classic Industries was $75.99 and it attached to the dash with nuts and screws same as my original one did. Even looked the same in every detail.
08-04-2022, 08:29 PM | #11 |
Who Changed This?
Re: Dash Pad
Good to know. Since I have three-point restraints, I'm thinking of making a wood dash "pad". Can't get a head bonk, if your head can't reach the dash. I have enough wood and tools to make that happen. It "wood" match the new instrument cluster, if I go that way.
08-05-2022, 06:12 AM | #12 |
Re: Dash Pad
You may want to check out the Truck and car shop , It's a counterpart piece listed as the "best on the market" , They are $61.00 and comes with the hardware . They have a metal core the studs are mounted to . The trick to installing any dash pad replacement is to not over tighten them and create a wavy look .
http://www.truckandcarshop.com/ https://issuu.com/truckandcarshop/docs/ts_60-72_web
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
08-05-2022, 08:21 AM | #13 | |
Re: Dash Pad
08-05-2022, 03:05 PM | #14 | |
low n' slo
Re: Dash Pad
08-06-2022, 02:37 AM | #15 |
Re: Dash Pad
In the dark days before the Internet and even LMC Truck. I had a long thin strip of saddle vinyl left over from reskinning the '69 T-Bird electric seat in my '68 C/10 Stepside. My original Dash Pad was shedding big flakes of silver-fawn plastic every where I touched it. So I accelerated the process with a putty knife and had it back down to bare foam. The form of the foam was still good, so I measured my Naugahyde and saw there was enough for a full wrap around. I shot the foam with 3M 77 contact cement and shot the same stuff on the under side of the vinyl. I carefully applied it. I had to make little hospital corners on the ends. These I tacked down with leather rivets.
So the Dash Pad matches the Seat. Same bolt of material. I then reattached it to the dash, and it's been there for about 40 years.
08-06-2022, 09:26 AM | #16 |
Who Changed This?
Re: Dash Pad
Sadly, my pad has dents from things being installed onto it over the years. Yours looks nice!
08-06-2022, 04:25 PM | #17 |
Re: Dash Pad
My O.E. dash pad in my 1969 C-10 is in really sad shape . Gotta wonder how a new one would stand up to the sun ? Anyone have experience with this ? Thanks !
08-06-2022, 05:18 PM | #18 |
Who Changed This?
Re: Dash Pad
Well, the way my truck is parked, and with the shell over the cab, the dash pad isn't going to see much sun. Maybe I'll have my wife make a cover for it. We went to Mexico (walked across the border) a little over 20 years ago and bought some wool blankets. We'll have one on the seat for protection against scorched hams from that new black vinyl.
08-06-2022, 05:21 PM | #19 |
Re: Dash Pad
I have a new one in my 69 C-10 and it sits outside all year round. No issues yet after 3yrs.
08-06-2022, 06:11 PM | #20 | |
Re: Dash Pad
I did have a Factory Defect issue with the first one they sent me. The embedded mounting stud -- all the way right [very hard to get to] was slagged. Like the threaded end had been melted by something very hot and no way could you start a nut on it. I sent it back and it was replaced. Brothers has changed hands recently, but all these vendors use the same sources for parts.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 08-08-2022 at 04:08 PM. |
08-06-2022, 06:36 PM | #21 | |
Re: Dash Pad
www.sciplus.com P/N:93201...Styrofoam Cutter.....$22.95 But if that's too much hassle buy the replacement pad from a reputable vendor. LMC's got a p/n:38-8120 for $69.95 Funny, they also carry ''Dash Pad Covers'' ...P/N:38-2606 for $169.95... A hundred bucks more for just a cover? No thanks. The Dash Pad Assembly is a much better deal. You do have to pull out your Instrument Panel. A/C ducting, Heater Controls, Radio, and Glove Box Liner to do a full install.
08-06-2022, 06:53 PM | #22 | |
Who Changed This?
Re: Dash Pad
08-06-2022, 07:12 PM | #23 |
Re: Dash Pad
The one I purchased was from "alknochinteriors.com"
The studs were not positioned correctly. Just another example of crappy design or maybe execution? I had purchased Corvette parts from them in the past and was very happy with the product. On the plus side they made the pad in Parchment and no one else did that I could find. It eventually went on but it was a PITA, like most aftermarket parts. I did have the option of sending in my core, which would have likely avoided my issues. I had thrown it out as I thought "what would I need this for?". |
08-08-2022, 01:42 PM | #24 |
Re: Dash Pad
Thanks guys !
08-20-2022, 11:15 AM | #25 |
Re: Dash Pad
For my '67 I did a remove and replace on the dash. Easy to do since the cab was stripped down. However, I did use a dash cover on my '89 Toyota pickup. It is more of a plastic cover than pad. Fit up was great and color matched well.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
