Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 09-28-2011, 12:57 PM   #1
vikasintl
Question What can be the reason why windshield wipers stops working after few minutes?
What should I check?
This is in GMC S15 truck
why both wipers stops working after a few minutes of use?
it stop suddenly and than after a while starts on its own???
what can be the problem and solution?
vikasintl is offline   Reply With Quote
Old 09-28-2011, 08:13 PM   #2
BarryB
BarryB's Avatar
Re: What can be the reason why windshield wipers stops working after few minutes?
Does the truck have intermediat(sp?) wipers?? If so the control module for the them could be bad. Or your wiper motor is on its way out. I've seen motors work until they warm up then quit. cool down, take off again. Thats my .02 worth
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 10-01-2011, 05:10 PM   #3
truckdude239
truckdude239's Avatar
it could also have a bad pulse board
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 10-02-2011, 12:12 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
The infamous bad circuit board problem!! Easy fix and you can do it yourself!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-02-2011, 07:15 AM   #5
68C15
blood type; Retumbo
68C15's Avatar
your truck is suicidal and wants you to not see the tree before it slams head-on into it. have a nice man to truck talk with it over a quart of 5w30. I can give you talk advice if you tell me how old he is.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 11-09-2011, 05:42 PM   #6
98layinframe
98layinframe's Avatar
^haha!
Yeah depending on the year, its a very common problem. Pull the circuit board in the wiper motor housing out and resolder the larger connections. The weight of the harness bouncing around is/was enough to break the crappy cold solder joints.
98layinframe is offline   Reply With Quote
Old 11-13-2011, 09:26 PM   #7
HotWheels4000
HotWheels4000's Avatar
mine does that too.
84 C10 lwb
89 S15 Jimmy 4x4
HotWheels4000 is offline   Reply With Quote
windshield, wiper, wiper arms, wiper motor
