Old 09-02-2019, 08:09 PM   #1
clay68c10
clay68c10's Avatar
Motorhome Tilt Column
$275 shipped in lower 48 or $250 local pickup
Please respond in thread only per board rules, first "I'll take it" gets it.
Selling a motorhome tilt column. From a mid 80s GM chassis
I moved the NSS down so it's a bolt-in for your 67-72.
I put the switch 1/2" further up the column from the truck location so you can install it 1/2" closer to the firewall for more room.
I used my multi-meter to adjust it, you may need to fine tune it after install.
It has a part # sticker with 1985 on it
Turn signal has no lever
Turn signal switch is tight and cancels as it should
Includes the cancel cam
The gray illumination wire is original length
Includes a long pigtail for the Neutral Safety/Reverse switch
Tilt mechanism is tight and smooth.
The 4 bolts in the tilt mechanism that typically loosen over time have been removed and reinstalled with lock-tight.
Tilt pivots were cleaned and lubed when removed to tighten the bolts.
The bottom bearing was cleaned and greased
The upper bearings are tight and smooth
The shift indicator bulb was replaced and tested OK, it has the green shade on it.
Shifter lever end (inside column) is good, pivot is average
Shift arm and adjuster lever have nice chrome, they shine up well.
The finish on it is OK, great for a driver. Some scratches as pictured. It would probably buff out nicely.
It has the original gear indicator, it has some sun damage but not all chalked out
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-02-2019, 08:11 PM   #2
clay68c10
clay68c10's Avatar
Re: Motorhome Tilt Column
Pics
13 Tahoe LTZ
Old 09-02-2019, 08:13 PM   #3
clay68c10
clay68c10's Avatar
More pics
13 Tahoe LTZ
Old 09-04-2019, 10:41 PM   #4
clay68c10
clay68c10's Avatar
Bump
13 Tahoe LTZ
Old 09-07-2019, 10:18 AM   #5
clay68c10
clay68c10's Avatar
Ttt
13 Tahoe LTZ
Old 09-13-2019, 12:34 PM   #6
clay68c10
clay68c10's Avatar
Bump
13 Tahoe LTZ
Old 09-17-2019, 06:45 AM   #7
SoCoC10
SoCoC10's Avatar
Might be interested for local pickup. Interested in any trades? Set of 4 nub 6 lug 15X6 or set of 6 lug truck Rally wheels with caps and rings? Rallys were blasted and painted.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 09-17-2019, 10:03 AM   #8
clay68c10
clay68c10's Avatar
I might be
PM sent
13 Tahoe LTZ
Old 09-18-2019, 12:22 PM   #9
rdsaw
How about 250 shipped? Kansas 67672
rdsaw is offline   Reply With Quote
Old 09-18-2019, 01:13 PM   #10
clay68c10
clay68c10's Avatar
Can do, PM sent
Sold!
13 Tahoe LTZ
Old 09-18-2019, 09:46 PM   #11
SoCoC10
SoCoC10's Avatar
So I'm not meeting you on Saturday? Wow looks like I just got jumped over.
Old 09-18-2019, 10:35 PM   #12
clay68c10
clay68c10's Avatar
SoCo,
Sorry, but I didn't think I skipped you.
You PM offered me $200 at 0837 yesterday and I countered $220 at 0930 for local pickup.
After that you didn't respond to my counter offer so I figured you weren't interested or had found another one.
Today at 1022 I accepted the offer from rdsaw.
Man, I'm not trying to skip over anyone.
I will have another one available in about a week, in similar condition. If you are still interested I can automatically put you first in line, PM you, call you, or whatever works.
Again, sorry for the misunderstanding.
13 Tahoe LTZ
motorhome, tilt, tilt column, tilt steering column
Copyright ©2000 - 2022, vBulletin Solutions Inc.
