02-14-2021, 11:14 PM | #1 |
GL-4 or GL-5 80w90?
Got a sm420 that needs an oil change. I heard that gl-5 80w90 has additives that don’t mesh well with older brass internals of the gears. Is this true?
Any recommendations on the correct oil. Posted via Mobile Device |
02-14-2021, 11:33 PM | #2 |
Re: GL-4 or GL-5 80w90?
From the website of a lubricant manufacturer:
The main difference between GL-4 and GL-5 gear oils is the amount of EP additives. Sulphur/Phosphorus containing products are used as EP-additive. This additive has the purpose to prevent the occurrence of micro-welds on the gear flanks at the local high temperatures which prevail in EP circumstances (temperatures well in excess of 800℃!) GL-5 has roughly twice the amount of EP additives compared to GL-4, which is why it is often used in high-pressure circumstances such as in a front axle and rear axle differential. Sulphur/Phosphorus additives however have an unfavourable property: they can react aggressively towards bronze and copper. This can be disastrous for the synchromesh rings of a gearbox. Therefore it is not recommended to use GL-5 in a gearbox unless the manufacturer allows this.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
02-15-2021, 01:09 AM | #3 |
The guy who did my 4 speed recommended "Driven" brand GL4 which you can buy at Summit.
02-15-2021, 11:20 AM | #4 | |
67 C10 Fleetside SOLD 67 C10 SWB Fleetside 67 C20 Fleetside 68 C10 Fleetside 68 C20 Fleetside SOLD 72 k20 Pay Pal: Grant.Furneaux@gmail.com |
