10-21-2014, 08:34 PM | #1 |
true 4wd?
I have a 72 gmc 2500 4th with Dana 60 rear and Dana 44 front. Just curious if these would each have a limited slip meaning that all 4 wheels will turn should I need them too?
1974 Plymouth Satellite (driver, project) 1972 GMC 2500 (future project, does drive though) |
10-21-2014, 08:49 PM | #2 |
Re: true 4wd?
What does your SPID say?
All 4 will turn and put power down as long as they have approximately equal traction. With open differentials the tire with the LEAST traction gets all the power. But to answer your question you will have to do a little more due diligence... Rear limited slips or even lockers in the 20 series trucks aren't uncommon. Limited slip fronts were optional but pretty unusual. No way to answer that question on the interwebs with insufficient info provided...
10-21-2014, 09:14 PM | #3 |
Re: true 4wd?
So it wasn't a standard equipment thing? I'm gonna have to crawl under there lol.
10-21-2014, 09:18 PM | #4 |
Re: true 4wd?
Agree with Mike C. Limited slip in the rear end is not uncommon. Limited slip in the front end is less common. It was not a standard thing, it would have been an option and listed in the SPID if factory installed.
10-21-2014, 10:28 PM | #5 |
Re: true 4wd?
All 4 wheels should pull in slippery conditions if you ride the brake a bit while giving it gas...
10-21-2014, 11:27 PM | #6 | |
Re: true 4wd?
Old farmers trick. I have done that and it has actually worked a few times.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. |
10-22-2014, 12:29 AM | #7 |
All about them K’s
Re: true 4wd?
That's exactly how a lot of the modern traction control systems work. The abs applies brake pressure to the wheel with less traction giving the wheel with traction power....
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
10-22-2014, 07:17 AM | #8 |
Re: true 4wd?
Buy some gaskets and pull the covers. Pretty easy to see if you have open differentials or positraction and the added advantage is that you change out what is most likely decades old gear oil and the covers get some new gaskets.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
10-22-2014, 08:54 AM | #9 |
Re: true 4wd?
Actually, open front and rear differentials is "true" 4wd. Front and rear posi is "better" 4wd
10-24-2014, 02:44 AM | #10 |
Re: true 4wd?
I checked the codes in my glove box, turns out I have a rear limited slip or power loc, nothing to note on the front other than the locking hubs lol.
Now to decide if I want to stick with the power loc, which if I remember correctly is a clutch type or switch to helical (I like the lack of maintenance).
10-24-2014, 08:39 AM | #11 |
Re: true 4wd?
Where I live, helical suck for off road. Deep soft sand is not it's friend.
Power locs are great. The more load the tighter the clutches hold.
10-24-2014, 09:11 AM | #12 |
"Ochre Ogre"
Re: true 4wd?
I have wanted to do this ever since I parted out a 68 GMC 2wd that had a Dana 44 rear with 3.54 posi. These gears installed in a front Dana axle along with the Dana 60 posi 3.54 I have in 8 and 6 lug I have would make a nice 4x4.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
10-25-2014, 01:43 AM | #13 | |
Re: true 4wd?
The one reason I don't like the idea of clutch type lsd's is that they occasionally need rebuilding, whereas the helical type are less maintenance.
