Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 10-05-2021, 11:16 PM   #726
BAD1916
Active Member
Re: Project 67 DRGNWGN - 67 Burban!!
Originally Posted by kev2809 View Post
huge setback with this motor...was draining the oil to get it on the stand and a ton of milkshake came out....kind of down to 2 options now. called my buddy where I got it from and he said he has another 2001 tahoe I could get. but I have to sell what I have and whatever I get would go to him for the other truck. other option would be to pull the heads and send them to get rebuilt and/or pressure tested for cracks or warps.
Damn, I can feel the disheartenment(if thatís even a word) in this picture.itís a bummer but at least you have options and can get it sorted.
BAD1916 is offline   Reply With Quote
Old 10-06-2021, 07:56 AM   #727
kev2809
low n' slo
kev2809's Avatar
ya having no luck selling this yet though. I don't have Facebook so I posted on Craigslist, 5 miles, and offer up...no luck yet. I'm getting the front frame painted now along with the crossmember but that will be done by the weekend.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 10-06-2021, 10:07 PM   #728
kev2809
low n' slo
kev2809's Avatar
cleaned it up the best I could and brushed on some mastercoat coating. going to work on the crossmember the next couple days and hope I can get it on by the weekend
-_--_--_ _________
Old 10-07-2021, 12:40 AM   #729
BAD1916
Active Member
Looking good. My project is kind of in the same place right now. It would be nice if they went back together as fast as they came apart
Old 10-07-2021, 08:29 PM   #730
kev2809
low n' slo
kev2809's Avatar
lol yup so easy to rip apart and the next thing I know I have parts laid across my yard for a year
-_--_--_ _________
Old 10-15-2021, 12:45 PM   #731
kev2809
low n' slo
kev2809's Avatar
some of my pics don't want to upload....but anyways. got the crossmember sanded down and painted up and back on. 60 bucks in new grade 8 hardware
not sure which route I want to go down now, haven't had any bites on my donor truck so my motor issue is still at a stand still.
-_--_--_ _________
Old 10-25-2021, 08:16 PM   #732
kev2809
low n' slo
kev2809's Avatar
well, got the old ugly truck and motor sold and pulled in the replacement. 2002 tahoe, dash says 211k. waiting on my jump starter I ordered so I can try to crank it and see how it sounds. pulled off the wrecked stuff already. this one looks so much cleaner than the yukon one
-_--_--_ _________
Old 10-26-2021, 10:43 PM   #733
BAD1916
Active Member
Nice to hear the old one sold so you can keep moving forward��
Old 10-27-2021, 06:54 AM   #734
kev2809
low n' slo
kev2809's Avatar
ya I slapped a battery on it and cranked it and it sounds pretty good. couldn't drive it since the trans lines were throwing oil everywhere lol.
gonna pick at it over the week and hopefully have it pulled by next week
-_--_--_ _________
Old 10-31-2021, 05:39 PM   #735
kev2809
low n' slo
kev2809's Avatar
got it out and on the stand. started the minor teardown. going to order the gaskets mentioned above. hoping to have this motor dropped in within a few weeks but we will see.
-_--_--_ _________
Old 10-31-2021, 05:41 PM   #736
kev2809
low n' slo
kev2809's Avatar
little grimey in the front and also looks like it had an oil pan gasket leak
-_--_--_ _________
Old 11-01-2021, 10:43 AM   #737
LockDoc
The Older Generation
LockDoc's Avatar
Mine was the same way. I got lucky, I cleaned it all up and re-tightened the pan bolts and it quit leaking. Mine had some modifications done to it before I got it and I wonder if they forgot to go around and double check the bolts.
I don't think a few weeks is out of the question for a timeline unless you have trouble getting something you need.
Keep us posted on your progress.
LockDoc
Leon
Old 11-01-2021, 01:41 PM   #738
kev2809
low n' slo
kev2809's Avatar
LockDoc
ya I'm not worried about the pan anyways I have a holley knockoff for the ls swap to go on anyways so that gasket was getting changed. I ordered my gaskets last night, should be in by the end of the week. will be getting at the trans crossmember today hopefully so I can have it ready to redrill
-_--_--_ _________
Old 11-01-2021, 07:53 PM   #739
LockDoc
LockDoc's Avatar
Good deal.
My engine was an LS1 so I didn't have to change anything on it.
LockDoc
Leon
Old 11-01-2021, 08:11 PM   #740
kev2809
low n' slo
kev2809's Avatar
Good deal.
LockDoc
only reason for the pan change is because the air ride. believe the pan will hang too low.
-_--_--_ _________
Old 11-02-2021, 02:04 PM   #741
LockDoc
LockDoc's Avatar
Yes, I'm sure it would.
LockDoc
Leon
Old 11-10-2021, 01:14 PM   #742
BigBird05
I am chasing oil leaks on my 03 Yukon LS. Do you have any good pictures of the LH side of the engine?
BigBird05 is offline   Reply With Quote
Old 11-10-2021, 05:21 PM   #743
kev2809
low n' slo
kev2809's Avatar
little update got the motor cleaned, painted, and resealed for the most part. going to work on getting the headers on, motor mounts, then fix the leaky seal on the trans and they should be ready to mate back up
-_--_--_ _________
Old 11-10-2021, 05:22 PM   #744
kev2809
low n' slo
kev2809's Avatar
sure what exactly are u looking at? I can snap some pics and post em
-_--_--_ _________
Old 11-12-2021, 09:18 AM   #745
BigBird05
I am leaking a lot of oil. Are there any sensors or anything else on the LH side where it could be coming from. I already replaced them crank sensor seal.
Old 11-12-2021, 11:52 AM   #746
kev2809
low n' slo
kev2809's Avatar
the only sensor on that side is the coolant sensor for the ecm. is your leak coming from the top? only thing I can think of is valve cover or oil pan...?
-_--_--_ _________
Old 11-13-2021, 09:20 AM   #747
BigBird05
Thanks I know the vale covers are leaking and the rear main seal too. I am just trying to get all of the parts lined up so I only have to tear it down once.
Old 11-13-2021, 02:20 PM   #748
kev2809
low n' slo
kev2809's Avatar
looking more like a motor
-_--_--_ _________
Old 11-13-2021, 02:55 PM   #749
BAD1916
Active Member
Looking good!
Old 11-13-2021, 03:22 PM   #750
kev2809
low n' slo
kev2809's Avatar
thanks my drill bit came in about 30 minutes ago so I drilled and tapped the head....this made me nervous lol
I'm not sure if the stock 67 sender will work though. when I get to the cluster, I will be modding it like ls1nova did with the s10 speedo. I will be adding a clock and camaro tach, and delete the circuit board and make a harness. so not sure if the idiot gauge temp sender is used or the 5 hole cluster temp sender. I believe they are 2 different ones?
-_--_--_ _________
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
