Old 01-11-2022, 04:10 PM   #1
kipps
Hydraulic vs. Mechanical clutch -- when did the change happen?
The debate keeps surfacing on Facebook from time to time. Was there a specific model year change in the clutch pedal design? Was it a running change that happened in the middle of a model year? Did some factories change before other factories did?
Hopefully Keith Seymour or someone else with factory experience can chime in here.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 01-11-2022, 04:53 PM   #2
kwmech
Re: Hydraulic vs. Mechanical clutch -- when did the change happen?
1985
Old 01-11-2022, 10:39 PM   #3
kipps
Originally Posted by kwmech View Post
1985
Some folks say they've seen hydraulic clutches as early as 1984 model year. Other folks declare up and down that their 1985 truck came with a mechanical clutch from the factory. Was there possibly some variation in the assembly plants?
Old 01-12-2022, 01:55 AM   #4
kwmech
Possibly, from left over orders or inventory
Old 01-15-2022, 10:14 AM   #5
Axle
Axle's Avatar
How many different manual transmission where offered? Weight rating of the truck may also play into year difference disputes.
Axle is offline   Reply With Quote
Old 01-15-2022, 12:37 PM   #6
kwmech
Only 1 that I know of which was the SM465
Old 01-17-2022, 11:06 PM   #7
kipps
There were a couple others. There was a 833 transmission with four speeds, overdrive, a floor shifter, and was a side loader.
There was also at least one side-loader three-speed that was column shifted. I've never learned for sure if there was a second three-speed available or not.
Old 01-18-2022, 10:26 AM   #8
kwmech
3 on the tree in 85?? never seen one of those
Old 01-18-2022, 01:09 PM   #9
hatzie
Moderator
hatzie's Avatar
I believe it was 1985. My 1985 C10 came with a hydraulic setup and I had a 1984 with the old Z-bar setup.
Can't forget what a pain in the neck it was to bleed the hydraulic clutch on that truck.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-19-2022, 11:56 PM   #10
Mike C
Mike C's Avatar
I have an ‘83 crew with 4 speed that is mechanical and an ‘85 C20 and ‘85 C30 that are both hydraulic SM 465 setups. So after ‘83 and for sure by ‘85 but can’t speak to ‘84. Only one of those I’ve owned an auto.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-21-2022, 05:04 PM   #11
1957 Chief
Proud Vet that loves the USA
I have an 84, its a Z-bar like Hatzie mentioned.
Also have an 85 and 86, they are both hyd with the sm465 transmissions.
Bubba
1957 Chief is offline   Reply With Quote
Old 01-22-2022, 12:59 PM   #12
jlmerie
jlmerie's Avatar
I agree with the consensus. I got this out of a 1984 Blazer a few weeks ago. I do wish it had been an 85.
James
jlmerie is offline   Reply With Quote
