Old 05-18-2019, 03:04 PM   #1
ratfreak8871
th400 yoke conversion
can I take my fixed yoke and counter bore it to convert to one piece driveshaft? Surely someone has done this.
ratfreak8871 is offline   Reply With Quote
Old 05-18-2019, 03:14 PM   #2
mongocanfly
mongocanfly's Avatar
Re: th400 yoke conversion
Im not following what your asking...what are you trying to accomplish?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-18-2019, 04:00 PM   #3
Big Daddy Bear
Big Daddy Bear's Avatar
I did several years ago on a 4WD to 2WD Blazer conversion. I used a 350/TH400 from a 2WD Suburban that had the 2-piece driveshaft.
I had a buddy who was a machinist turn the inside splines down to allow the yoke to slip on far enough to clear the shaft. I also just cut the longer driveshaft down and welded the Suburban yoke end of the shaft on to the temp one.
Was not worried about balance at the time as I was doing it as a temp to be able to move it around while being built. The end goal was a new driveshaft cut specific to length to fit the Blazer.
At the time, there was also a conversion yoke being sold already set-up with the proper clearance, but I can't remember the specifics...
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
Old 05-18-2019, 04:01 PM   #4
JDL
JDL's Avatar
You can but you would hove to seal the hole that the bolt goes thru that keeps it in place on the trans. I think it would be easier to get one that is already set up to slide in and out for a one peace drive shaft.
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 05-18-2019, 04:19 PM   #5
Big Daddy Bear
Can be done, just have to balance cost of machine work/threading if you have to pay for it vs cost of the new yoke...
