03-03-2021, 08:49 PM | #1 |
67/68 grill support
I need help and pics please on my 68 grill. How does this mount? Either I have the wrong part or the grill is that bent. Thanks.
Live life one weld at a time. '04.5 Chev Duramax CCLB- Winter DD '03 Grand Prix GT- Summer DD '67 C10-307/T5(For Now)-R.I.P-Burned Up! '68 C10-5.3/4L80E www.one-guys-garage.com |
03-03-2021, 08:51 PM | #2 |
Re: 67/68 grill support
Here's pics.
03-03-2021, 09:27 PM | #3 |
Your holding it in the right location. Make sure that the trim nut is removed and reinstall it after the bracket is installed.
03-04-2021, 05:42 AM | #4 |
On the top of the bracket is those 2 welded nuts, the one will line up with the hole in the grill and the hood latch gets bolted to that spot and I think you will need to remove the chevy emblem because the longer leg of the bracket mounts under that emblem and is a hidden bolt. ( actually I think it gets a rivet there and it looks like the old rivet is still in the grill and will need to be removed so a new one can be used.)
