03-03-2022, 12:38 AM | #101 |
Re: 1972 Cheyenne Super coming apart to go back together
thank you sir,i appreciate the kind words,i'm glad you're following along.it's hard to believe,a bunch of oil leaks lead to all this but that's ok,it'll be a better truck when i'm done and we'll be driving by the time the weather gets better in a few weeks or a month but a little paint work first is on the agenda.you take care,Greg
03-03-2022, 08:17 AM | #102 |
Amazing work Greg. Looks as great as I figured it would!
03-03-2022, 10:50 AM | #103 |
03-04-2022, 07:01 PM | #104 |
well today went well,a fairly productive day.i installed the new A/C compressor clutch bearing and then all the bracketry for the A/C pump and then the pump,then all the lines,just temporarliy through,i'm waiting on "O" rings for all the connections,a new dryer and a few other odds and ends.i got my new rad in,the shroud and the upper and lower rad hoses,the transmission cooler lines in the rad.all the belts are on,the voltage regulator and horns are on and some wiring done.we're getting closer to hearing this run,i expect in the next day or two.take care.Greg
03-05-2022, 06:41 PM | #105 |
That's a lot of progress! Radiator looks really good. Sorry to hear about the repro gutters. I marvel at the mindset that allows something so simple to be manufactured so incorrectly. There is no way I would want to drill a hole in a truck like yours to make a piece.......... like that fit.
03-06-2022, 04:00 PM | #106 | |
03-06-2022, 04:18 PM | #107 |
well,a little more progress today.i managed to get my hands on a 20 year old,new in the package,repro wire harness gutter for the firewall,took that hard piece of plastic crap off the firewall that i just bought,and fired it in the trash along with it's brother for the rad support.i installed the new/old one in minutes,nice and soft,pliable,the way it's supposed to be,and what do you know?where there was a screw hole in the molding,there was a hole to match in the truck??now i have to come up with something for the rad support,as i think my trip to the Charlotte Autofair might be in thin ice??might not ever be able to afford the gas??i have to now come up with something for the rad support wire gutter.the fenders are on along with my repainted fender emblems,the new harness for the kickdown is on the turbo 400(thanks Dan)the battery is in and some other odds and ends hooked up and installed,waiting on some GM heater hose and clamps,that's about it,it'll be ready to start.
03-07-2022, 07:54 AM | #108 |
Looking amazing of course. You didn't get enough tower clamps? You had them shipped direct to you?
03-07-2022, 08:29 AM | #109 |
hi Dan,of all the things i've lost,i miss my mind the most,that GM hose is here,thanks again.i forgot and thought it was still on it's way.i did use several tower clamps and they all broke,more chinese junk??i'm going to have to use some regular gear clamps til i can get some more tower clamps.sorry for the confusion,all good.take care my friend.
03-10-2022, 08:30 AM | #110 |
6>8 Plugless........
I had the same luck with the tower clamps I got too. I hated removing them and now I hate the ones I just threw in the trash.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
03-10-2022, 08:41 AM | #111 |
hi Ryan,i feel your pain.i saved most of the original tower clamps from my truck,cleaned them and re-used what i could but needed more.the repro clamps all stripped as i tightened them up.pitiful load of garbage.i guess i'll have to go to work and find some more old original clamps if i want to use them.they are a pain but i like the look.take care.Greg
03-10-2022, 07:01 PM | #112 |
today was a good day,i got everything done and time to turn the key and watch this new motor come to life,it started right up,i went through the break-in procedure as mapped out by the machine shop,checked and topped up all the fluids.it ran today for probably 1 1/2 hours total,a little more running in the next couple of days and i'll get the break-in oil out of the engine and then switch gears to get ready for a little paint work.i love when a plan comes together.
03-12-2022, 08:21 PM | #113 |
today i worked on getting the moldings,windowfelt and the door handles off in preparation for some paint work.the new door lock installed,door panel cleaned and all the broken clips replaced,and the A/C condensor painted and installed along with a new dryer.today i made a pattern for the patch that's going in where the gas tank neck came out through the bed side,one more to fix on the other side.hopefully tomorrow,that passenger side patch will be in,then move onto the drivers side.
03-14-2022, 07:58 AM | #114 |
Nice, so glad cam and lifters gave you no trouble. I have been reading a lot about problems with the metal in the newer lifters. I am sure that breakin procedure included priming the oil and then running it at 2500 RPM or so for 10 minutes.
03-14-2022, 08:19 AM | #115 |
hi Dan.the motor seems to be running well and sounds fine.i used a new Mellings cam,lifters and rocker arms and followed what the machine shop had recommended and used the "Driven" brand break-in oil they suggested.the breakin-in procedure was different than what i had done in the past,with using 3 heat/cool cycles and high RPM.i don't know if it helped but it sure didn't hurt.it sounds great.there are and have been for a number of years now,people having cams and lifters fail on start up by not using high zinc oil and or not following directions.
03-14-2022, 08:27 AM | #116 |
Great to hear Greg! It looks like a new truck and I am sure will run great.
I have just recently heard of people doing proper breakin and installation and still having problems with lifters. I remember using high Zinc Oil on mine and following directions to the tee and also having an experienced friend here for first startup and all went well. It is a great feeling to get that first startup in! |
03-17-2022, 06:12 PM | #117 |
I've been working for days,not much to show for it.i made,welded in and cut out,2 panels I made for the aux gas door in the passenger side bed side.#3 went in today,just tacked in for now,i'll go back at it tomorrow.both attempts ended up not making me happy,not straight enough,so I made some changes,we'll try again.new window felts and glass channels arrived today.i'm just waiting for a new fuel strainer for the gas tank sender,i have the sender out for a new float,the original brass float wasn't "floating"i managed to tear the strainer so a new on is on the way.hopefully an update tomorrow with a gas door panel welded in and i'll be happy with it and move onto the gas door on the other side,remove all the trim,windowfelts,door handles,new door locks to install and get ready for some paint.
03-18-2022, 03:04 PM | #118 |
On the road
Amazing attention to detail, I'm loving this build
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
03-18-2022, 07:43 PM | #119 |
thanks Mike,i appreciate the kind words,glad you're enjoying it.i wasn't enjoying today,spending hours welding in the panel on the pass side to fill in the aux gas door,for the 3rd time,only to cut it out and throw it on the floor.i thought I knew how to do this but evidently not??try again tomorrow.take care.Greg
03-23-2022, 10:02 PM | #120 |
well it's been several days since an update,not because I haven't been working on my truck,i am but not much to show for it.this auxillary gas door I wanted to eliminate since I already had removed the 2 tanks,has proven to be pretty stubborn.i welded in 4 patches,cut 3 of them out but this one is staying.i think I can live with this one.i had a horrible time trying to keep the side straight and one more on the other side to do next.a little skim of bodyman in a can,it'll look as good as I new,i hope.of course another step ahead,and 4 back.i started up the truck yesterday to put the it outside,i had a customer's car coming in and needed the lift.the engine started but the most horrible racket came out from somewhere?turns out the new starter had stayed engaged in the flexplate and it wasn't happy.i switched it off but it kept running til I disconnected the battery,it stopped then.i checked the starter clearance today,did some shimming and seems fine again but I think I may take the nose cone from my original starter and install it on the newly rebuilt starter I bought.never a dull moment?
03-24-2022, 03:14 AM | #121 |
03-24-2022, 05:10 AM | #122 |
Awesome Progress. Had dual Aux tanks on my truck. Even with a full repaint it was a lot of work to eliminate them. Hope all goes well with the patch on your truck.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
03-24-2022, 08:20 AM | #123 |
03-24-2022, 08:22 AM | #124 |
hi Richard,thanks.i'm sure we'll get this figured out.i had a look at your truck,awesome work.take care,Greg
03-24-2022, 12:08 PM | #125 |
Nice work on the patch Greg .... won't take much of a skim of mud at all to smooth it out. Your attention to detail is amazing but your patience is next level sir!
No doubt your vital signs must have been heading north up until you found out it was the starter. Yikes -->> phewff! |
