10-13-2020, 05:38 PM | #1 |
hubcap question
Does anyone have a good chronicle of what hubcaps came stock on the squarebody trucks? I've seen an earlier and a later style of dogdish, but I don't know where the split was, or if there were more styles than that.
I've found a excellent thread on this site for 60-66 hubcaps, but I haven't found anything for the 73-87 hubcaps.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
10-15-2020, 01:47 AM | #2 | |
Re: hubcap question
For reference 1/2 ton caps measure 10.5" diameter and 3/4 ton caps are 11.75" 1969-1972 1973-75 (these are 3/4 ton) Same as 69-72 but with Ochre colored bowtie 73-75 3/4 ton GMC In 1976 they went to the next style, the flatter caps. Not 100% sure when they quit putting hubcaps on, perhaps all the way up till 89... That's more or less it in terms of dog dish caps. There were a few different full wheel covers seen on later suburbans and trucks, as well as ralley wheel center caps... But as far as dog dishes go... that's it.
"Sweet Pea" 1975 Cheyenne 20 http://67-72chevytrucks.com/vboard/s...00#post8477900 "Bourbon" 1975 Suburban ScottsdaleSOLD https://67-72chevytrucks.com/vboard/...49#post8769049 ”Otis” 1970 C10 SWB -SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=762766 ”Chebby” 1962 Impala LS/TKO-500 http://www.pro-touring.com/threads/1...2-Impala-Build |
10-15-2020, 06:01 AM | #3 |
Re: hubcap question
Thanks, that's perfect!
One thing I have noticed on the "spoke" style dogdish, is the 5-spoke caps fit the 15" 1/2-ton wheels, and the 6-spoke caps fit the 16" wheels on the heavier trucks. I don't know if this same thing applies to the 1973-1975 caps or not.
10-15-2020, 09:47 AM | #4 |
Re: hubcap question
Definitely correct for the later caps. 5-spoke = smaller OD for 1/2 ton wheels/caps; 6-spoke = larger OD for 3/4 or 1-ton.
10-18-2020, 10:09 AM | #5 |
Re: hubcap question
Yes, all true, however, the base model pickups continued to use the white painted '73-'75 style as standard equipment thru the '78 model year. In '79 to '87, all models came with the flatter caps
10-18-2020, 11:33 AM | #6 |
Re: hubcap question
One nuance about the early 73-75 3/4-1 ton PO3 caps is that there were concave (innie) and convex (outie) varieties of the yellow bow tie center. 67-72 PO3s for 3/4-1 ton were all convex outies. Convex 73-75 PO3s seem to be fairly uncommon, most that I’ve seen were concave. (and note all 1/2 ton PO3 caps are concave innies).
