04-02-2020, 06:26 AM | #1 |
82 rear lower
I bought this truck with a rear lower kit in it and I have it as low as the kit allows , just wondering if this front lowering mount is as low as there is or is there a lower one ????? , just want the rear of this thing about an inch lower
04-02-2020, 07:37 PM | #2 |
Re: 82 rear lower
Has it got an axle flip kit in it? If so put a block in it. If not put a flip in it and then adjust the shackle to get it the height you want.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-02-2020, 08:37 PM | #3 |
Re: 82 rear lower
04-03-2020, 06:45 PM | #4 |
Re: 82 rear lower
It would be your best way of getting what you want.
Jimmy
04-04-2020, 01:11 AM | #5 |
Re: 82 rear lower
I think he is beyond doing a flip kit.
A flip kit usually nets about 6" of drop. His bracket lowering is usually good for 4 inches depending on manufacturers. So combine the 2, and he is on the ground. I see only 2 options here. 1. De-arching your springs for the drop you want, and using your adjustable shackle to dial it in. First I would run the bolts down a couple of notches. That way you build in some adjustments. 2. Put the factory hangers back on, and the so a flip kit. |
