05-20-2016, 04:18 PM | #226 |
Re: Best "Rake/Stance" for a Hot Rodded 60-66 C10?
05-20-2016, 04:20 PM | #227 | |
05-20-2016, 05:26 PM | #228 |
But Found Her 25yrs Later!
I don't remember where I found that pic.
08-31-2016, 02:58 PM | #229 |
08-31-2016, 03:01 PM | #230 |
That is one way to keep stuf from rolling around in your bed.
08-31-2016, 03:07 PM | #231 |
Looks like he doesn't have a tailgate.
So the 'Rake' may be his only option for keeping stuff in the bed.
08-31-2016, 04:29 PM | #232 |
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
08-31-2016, 08:28 PM | #233 |
08-31-2016, 08:48 PM | #234 |
66
_____________________________________ 66 C10 shortbed stepside KEEPER 66 C10 longbed stepside SOLD 69 C10 shortbed stepside SOLD 71 C10 custom deluxe long fleetside SOLD _____________________________________ |
08-31-2016, 10:32 PM | #235 |
Who makes the best springs and shocks to get the best ride? Was gonna go air but too expensive at the moment. Is it better to use rear drop springs, or is using blocks better.
08-31-2016, 10:53 PM | #236 |
From what I have heard it is best to go with drop spindles in the front and use drop coils to do the rest. In the rear go with 2 inch blocks first and them do the rest with drop coils. By doing this you will maintain the most amount of suspension travel. Even if you do not decide to lower it more with drop coils it is still a good idea to get new coils and shocks. If you go low enough in the rear you will probably want to get shock relocation brackets because the angle of the shock will be to grate when you lower it. If you get drop coils you will also need shorter shocks.
08-31-2016, 11:22 PM | #237 |
My '60. Has 4" drop spring out back and torsion bars cranked down up front. I have the 2 1/2" drop spindles in the garage right now, just waiting on some cooler weather out here to put them on.
1960 C10, shortbed, step side, big back window, 350, Turbo 400 |
09-01-2016, 12:35 AM | #238 |
Where do most people get their drop block for the rear, I am wanting a 4" drop in the rear and 2.5-3" drop on the front, the front I will just be buying drop spindles with stock springs, the rear. I looked at cpp springs, but want a really good quality spring that isn't too harsh?
09-01-2016, 04:58 AM | #239 |
I've used Early Classis Enterprises 4/6 kit plus a front sway bar on my trucks for many years now, and I'm very happy with the ride quality and handling.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
09-01-2016, 11:49 AM | #240 | |
I have cpp drop coils in the rear but I can not comment on the ride quality because I realized that my shocks were at full extension at ride height. I have just recently had them relocated but have not had a chance to drive the truck sense. I have heard a lot of complaints about cpp customer service but have not had that problem my self.
11-07-2017, 12:40 AM | #241 |
11-07-2017, 08:02 AM | #242 |
2-1/2" drop spindles and 1-1/2" drop blocks with 29"/31" tires.
11-08-2017, 12:28 AM | #243 |
At my worst I'm at my best |
11-12-2017, 02:05 AM | #244 |
11-13-2017, 12:17 AM | #245 |
60-66 Nut
I kinda like it........
11-13-2017, 12:11 PM | #246 |
That is one massive rake. I think you would need velcro seats. But vary nice rendering.
12-05-2017, 09:03 PM | #247 |
Here's mine, 2.5" front, 2" blocks in the back, hope to lower it more with new wheels/tires soon[/quote]
I like this one the tires fit the opening perfect! I hope to get mine sitting like these
http://67-72chevytrucks.com/vboard/s...d.php?t=765151 Last edited by jimmythompson1964; 12-06-2017 at 11:22 PM. |
12-05-2017, 10:28 PM | #248 |
These are awesome, keep it coming.
03-19-2019, 07:03 PM | #249 |
Not mine
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 03-19-2019 at 10:48 PM. |
03-19-2019, 08:14 PM | #250 |
Mine in Rendered Rides
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
