10-18-2020, 09:40 AM | #176 |
Re: My 1968 C-20 Golden Anniversary Project
THANKS DALE!
Found out that the NOS flame arrestor #3857476 is wrong- too big, see picture. Fortunatly I have a complete set from our fellow ROOGER KOOP here in the forum.
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 10-18-2020 at 09:46 AM. |
10-18-2020, 10:01 AM | #177 |
FOUND THE RIGHT FITTINGS FORE THE OIL PRESSURE GAUGE AND VACUUM GAUGE INSTALLATION.
NAPA 302X2, 6200X2, 6100X2 LMC truck 36-1923 Oil Pressure Tube Kit-49", 31-3406 Vacuum fitting-Tee-Barbed,31-3404 Barbed Fitting-Gauge Bolts Air intake Manifold: ARP 134-2001
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 |
10-18-2020, 10:18 AM | #178 |
Preparing Water outlet, found out that my manifold despite the same casting number as the original has not the hole for cooling water (connection to pump), therefore I try the riser (thermostat above the opening for the hole)
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 10-18-2020 at 01:44 PM. |
10-18-2020, 10:23 AM | #179 |
Some more pictures:
Gasket FEL-2202 Vintage Air water Neck Riser VTA-706001-VCQ Water outlet four seasons 84820 Thermostat: Mr Gasket #4365 195° Fahrenheit (90.5° C)
10-18-2020, 10:30 AM | #180 |
Further manifold accessories:
Vacuum fitting (for power brake, heating/air condition reservoir & transmission TH400, spigott must be inside the fitting. Distributor fittings
10-18-2020, 10:39 AM | #181 |
Rockerarm Kit SUM -G6800 1.5 Ratio, Fits 3/8" studs
Hydraulic lifter Federal Mogul HT-817 Engine Mount screws totally stainless 6-2259
10-18-2020, 10:51 AM | #182 |
Temperature sending unit: 01513321
Preparing exhaust manifolds #3896956 #3855163 Exhaust Manifold LH (Driver): 3855163 L.H (Cast 8155163A or 3855163A), interchangeable 387241 Exhaust Manifold RH (Passenger): 3896956 R.H. (discontinued use 3905364 or 3932469) Preparing some measurements camshaft degreeing
10-18-2020, 10:56 AM | #183 |
Oil dip stick Kit PRO-66116
Some pictures regarding exhaust gas mainifold heat shields
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 10-18-2020 at 11:07 AM. |
10-23-2020, 08:18 PM | #184 |
Amazing work Gerhard! You're going to have the nicest C10 in all of Germany
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
08-09-2021, 10:08 AM | #185 |
Last entry from 10-18-2020, 04:56 PM , was completly frustrated, because of the not matching valve timings (tested with Summit Degree Wheel), after studing and learning alot now new hope, start soon.
08-10-2021, 06:45 AM | #186 |
Proprietor of Dale's Corner
Goodness, you're getting technical. I'm glad to see you're still around....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-26-2022, 04:24 AM | #187 |
Hobby is gone, truck sold, was a nice time here in the forum
05-26-2022, 07:13 PM | #188 |
Noooo! Say it isn’t so. Call it temporary, leave the door open just in case another truck happens to cross your path.
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Project "Little Sister" (70 c10 blue original paint refresh) Project "C10 Fever" (68 factory black 396 swb) Project "Blue Bomb" (70 c30 blue original paint refresh) Project "Vitamin C" (71 c10 orange original paint refresh) |
05-28-2022, 05:52 AM | #189 |
Oh man, hadn't seen this build before, was just getting into it. I've never seen such detailed care taken in engine assembly. Good luck Gerhard. Sorry to hear that you sold it, but sometimes that has to happen. Hope to see you back. It looks like you got it all together. How did it run?
05-30-2022, 06:58 AM | #190 |
You can still stop in Gerhard.
05-31-2022, 05:00 PM | #191 |
I'm surprised! What's the next project Gerhard?
09-22-2023, 12:18 PM | #192 | |
I knew this was going to happen I gave, made, sold many parts to Gerhard and tried to give him a lot of common sense advice but being a German engineer he was determined to complicate the living dung out of everything. I always wondered if he'd frustrate himself into packing it in which looks like finally happened - so sorry , too bad Jerry in Canada |
Tags |
327, c-20, golden anniversary, th400, truck |
