05-31-2021, 09:41 AM | #1 |
Electric choke
Good morning everyone, I need help ( wife tells me that everyday) I’m trying to hook up an electric choke wire 12v in my truck. Says must be on keyed ignition.
Can I wire to alternator or do I have to wire to ignition switch? If so what terminal on key switch should I use? Thanks for any help.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
05-31-2021, 04:35 PM | #2 |
Re: Electric choke
The best place to wire it would be at the fuse box. There is a terminal marked ign. unfused. Put an inline fuse in the wire about 10 amps. Do not hook it to the alternator.
George |
05-31-2021, 06:14 PM | #3 |
Re: Electric choke
Thank you.
06-01-2021, 12:21 AM | #4 |
Re: Electric choke
The alternator would be a bad choice. Since it would always receive power, you might as well not have a choke. You need to make sure that whatever source you use does not have power with the key off.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
06-13-2021, 08:48 AM | #5 |
Re: Electric choke
Did what you said and the choke works great, thank you.
Thread Tools | |
Display Modes | |
