Old 07-01-2019, 08:38 PM   #1
ibinyth
Th350 broken vacuum modulator bracket tab
Driving down the road after a fluid change all of the sudden I'm spewing fluid all over the road. After a $60 towing bill and time to get around to examining I find my issue. Vacuum modulator, and bracket both missing. Assuming the bolt bracked out however, the tab apparently broke at some point in the trucks life and was simply bonded back on. What's the best possible way to reattach it as its simply a 1/4 wide piece of threads and I plan on doing a 700r4 swap in a few months.
ibinyth is offline   Reply With Quote
Old 07-01-2019, 08:39 PM   #2
ibinyth
Re: Th350 broken vacuum modulator bracket tab
http://imgur.com/gallery/p3FPoUr
Old 07-01-2019, 08:44 PM   #3
ibinyth
NEVERMIND
Think I figured it out... When I did the fluid change someone had wire wrapped around the crossmember. Me not thinking anything of it as it didn't look to be doing much I cut it. Guess I figured out its purpose after all
Old 07-02-2019, 01:50 PM   #4
tdangle
tdangle's Avatar
Always interesting how these trucks were "fixed" throughout the years. Never get away with it on newer cars/trucks.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 07-07-2019, 03:50 PM   #5
sKnNyPpY
sKnNyPpY's Avatar
Longer bracket bolts to the extension housing. https://www.transmissionpartsusa.com...-00047307b.htm
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 07-07-2019, 04:05 PM   #6
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Originally Posted by sKnNyPpY View Post
Longer bracket bolts to bell housing. https://www.transmissionpartsusa.com...-00047307b.htm
Nice find! Bolts to the "Extension Housing"
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 07-07-2019, 04:22 PM   #7
sKnNyPpY
sKnNyPpY's Avatar
oops, edited. I was working from memory and it was written right there in the link! Part works great BTW, for some reason I still had to use multiple o-rings on the modulator to keep from leaking/sucking air though.
th350, vacuum modulator
