09-07-2022, 10:39 AM | #1 |
Has anyone replaced the front coils with airbags?
Hi I have a 78 shortbox with drop spindles and I want to replace the front coils with airbags has anyone done this? I have airbags just wondering if one needs to fab up specific brackets or just do some straight spacers and bolt them in?
09-16-2022, 11:43 PM | #2 |
Re: Has anyone replaced the front coils with airbags?
Probably depends on how low you want to go. Most I see cup the lower arms to get even lower. Probably going to have to fab something up to work though
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-17-2022, 06:26 AM | #3 |
Old Heap Driver
I bagged my 80 square stepper several years ago. I bought a bracket kit that was basically a cup for the lower and a plate for the upper mount. I don't remember the brand name but I had zero issues with thousands of miles driven. The truck went to a new owner roughly 4 years ago and he still cruises on the same setup.
This shot is aired out, if you want to go lower be prepared for a bunch of fab work.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '30 Model A Pickup, suicide front end, 350, 350, traditional style hot rod. |
09-21-2022, 07:24 AM | #4 |
If you want to fab them you can but they are out there pretty cheap.
https://www.crownsuspension.com/lowe...ower-bag-cups/ https://www.crownsuspension.com/lowe...er-bag-plates/
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
