08-02-2022, 06:46 PM | #3026 |
Re: What did you do to your truck today.The 3rd chapter
I knew I’d find the spindle and lower control arm if I kept digging . This isn’t even with any power tool all I did was wire brush after scraping .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
08-02-2022, 06:58 PM | #3027 |
Washed it, and peeled off some of the stickers on the back window. I'm not a fan of wearing my politics on my truck. Worse yet, wearing someone else's politics on the back of my truck. Yesterday, I ordered a new steering wheel, adapter, and quick release. I plan on making it as hard to steal as possible.
08-03-2022, 09:40 AM | #3028 |
Looks like you've busy.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
08-03-2022, 10:22 AM | #3029 | |
08-07-2022, 11:08 AM | #3030 |
Attachment 2210010Changed around wheels and tires.
1987 V30 Silverado SRW 454/400 4x4 104k original paint 1992 K3500 Silverado SRW 454/4L80e 4x4 114k 1971 K20 Cheyenne: http://67-72chevytrucks.com/vboard/s...d.php?t=804580 https://67-72chevytrucks.com/vboard/...d.php?t=837441 Instagram: jt_trucks3500 |
08-07-2022, 06:20 PM | #3031 |
Fantastic truck, JT!
I didn’t do much. Guy came by to pick up some letters for the hood of his 68 and brought me a trade. Actual front license plate from the period for my truck. It’s about 1.5x thicker than new plates these days. Couldn’t help but put it on.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
08-08-2022, 12:07 AM | #3032 |
At the body shop.
Decided our master cylinder is leaking, not the wheel cylinders.
And worked on teaching my son how to navigate the crazies.
" That didnt make it any newer " " Dont antique the equipment " |
08-08-2022, 09:21 AM | #3033 |
after much grinder wheeling gave in..... sent it off to blast yesterday
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
08-15-2022, 02:04 PM | #3034 |
Got to the engine today . Need to pull the pulleys and paint also need a new temp sender gage works but sender is DOA . Also the upper and lower alternator brackets are cracked so I need to weld them up. Man I love the Eastwood SCT tool definitely have gotten my moneys worth out of it.
08-15-2022, 02:05 PM | #3035 |
Valve cover after paint .
08-15-2022, 02:47 PM | #3036 |
Looks really nice
08-15-2022, 06:00 PM | #3037 |
70+ ( Old Skool Club )
Front end rebuild commences.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-15-2022, 06:12 PM | #3038 |
The two broken brackets bottom one is totally broke off the top adjuster bracket has a crack .
08-15-2022, 06:15 PM | #3039 |
And anyone know why there would be an external resistor on the coil? As long as I’ve owned it there has been no wire coming out of it . Could it be for radio interference ?
08-16-2022, 09:29 AM | #3040 | |
https://www.championautoparts.com/Te...gnetic%20field.
08-16-2022, 10:19 AM | #3041 | |
08-16-2022, 11:51 AM | #3042 |
Who Changed This?
The resistor is in the harness in '68. That coil is a replacement; a factory coil wouldn't have that requirement printed on it. The item on the side of the coil is a capacitor (condenser); it is for suppression of radio interference due to the ignition. The capacitor inside the distributor cap also serves for noise suppression, but its primary purpose is for impedance matching the ignition circuit.
08-16-2022, 06:48 PM | #3043 | |
I did a little today . Looks much better with the chassis finished to contrast the engine. Painted the fan pulley and PCV parts going to finish the breather tomorrow. Never saw ridges on a pulley before .
08-16-2022, 08:25 PM | #3044 |
Who Changed This?
Never seen ridges like that, either. Weird.
It's looking good, in any event!
08-17-2022, 08:33 AM | #3045 |
Nice restoration work!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
08-17-2022, 09:56 AM | #3046 |
Thanks for the compliment . I see it more as a clean up than a restoration.
08-17-2022, 03:22 PM | #3047 |
Ok I ordered the PCV grommet from Napa guaranteed to fit my 68 250 ci . Well it don’t fit . The hole for the grommet measures 127/128 so one inch accounting for paint. The inside lip of the grommet is 1"3/16ths . I look at rock auto they have one but it’s oddly shaped . Maybe it’s correct I have no idea . Anyone have any suggestions . Don’t need anything else so I’d hate to spend $4 on shipping for a 1.58 part
08-17-2022, 04:19 PM | #3048 |
The grommet you show from Rock Auto fits 85-96 Chevy V-8 & V-6 steel valve covers. I dont think that one will work for you but hate to say for sure.
08-17-2022, 06:07 PM | #3049 |
I hate looking up parts half the time the info imputed by the programmer is wrong . Says it’s for my truck this is the first one in the list same unit different manufacturers.
08-17-2022, 06:59 PM | #3050 |
Did the air cleaner today. The snorkel was dented so I popped it out a bit and used some metal filler.
