#1751 |
Re: GRIZZ’s ‘79 - 2WD BLAZER Challenge over in London, England. “~It’s not a Project
Progress…?
How do you define it when you are so close that things blur in your line of vision. I guess the latest order off eBay is a bit of a refocus. Still a ton of cosmetic and setting up things to do, and for anyone who has not done this sort of thing themselves, or judge progress by the money they pay others to do the work only to then show off “their build” it is never going to be easy to understand why the car was not started over Easter or last weekend, or last night. Still, it will happen. @nickwheeler are probably as tired of fitting and removing the wheels, axle stands, wiring loom etc as the onlookers. Sally is a saint, putting up with it all, allowing me to go play most times I want. Remember the Moonwalk some of you sponsored her so generously for? That is on this weekend, and all I am contributing is to pick her up at the station on Sunday. Poor show from me. A very good friend (whom I have never met in person) gave me a real wake up call yesterday, pointing out where my priorities should lie. And he is right. But in the mean time, progress I guess can be defined by ordering 3 meters of carpeting for the car. Ohhhh, and buying £51.18 worth of Unleaded, that is 31 litres or thereabouts. Optimism is good. ![]() Hope to get to Car Builders Solutions to get the radiator hoses and bends after work today. Almost the weekend.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
#1752 |
FRIDAY 13th
BOOOOO…. !! ![]() Not that that is a problem in itself, but time is counting….. Or something like that. Hoses bought for the radiator and cooling system, £60.00 Fitting, priming, antifreeze etc, Weekend job. ![]() Mate @Craigrk is flying to India for work in two weeks time. I asked him to look into alternative LED headlights for the Rezin Rockit for me while out there. I can get these for around £80.00 each here in the UK. BUT - Aliexpress who do not shop to the UK it seems (I am often wrong) will supply them for around £30.00 each in India. Watch this space. ![]() Summer seems to finally be here. Hedges need to be cut, lawn mowed etc, so a load of non car build jobs to be done. Have a good day, it is Friday after all.
#1753 |
Right.
So where were we in this build? A never ending list of smaller jobs, all taking up time. The floors on the body have a weird diagonal join in the front footwells and revised resin and matting which brought a 15mm height irregularity into play. I had got a load of fiberglass matting and resin from a member on UKGSER last year with all intent to use it to create a level and stronger floor, but fiberglass is ambarsteward to work with and ultimately I decided to go for a plan B solution to the floor and position of the pedals. So the fiberglass matting and resin is again up for grabs if someone can use it and wants to collect it. PM me please. So yesterday morning I spoke to Mickey over the fence about some thick ply offcuts he may have, Failed, he had none, but knew where two 4x6 foot “used” sheets of 15mm ply was dumped at his sons home. So we jumper in the S10 and headed off to go scavenge and collect them. One was unused, rectangular and missing a 400mm strip the other must have done duty as a floor in a van, one side grubby, and a load of dried out paint on it, plus random cuts to it. Some more loose bits came home too. Love my Chevy, don’t use it enough but it is always ready to work. Treasures, and free money again as they were headed to a skip. The better sheet was already stashed in the garage for future reference. ![]() So the usual CAD work commenced, keeping in mind the two sides are completely different. ![]() Then transferred to the ply that I had cleaned up of the paint with a grinder and flap disc. Thanks @nickwheeler for photography duties. ![]() What the initial wood repaired and levelled, along with some brutal grinding down. ![]() ![]() Pedal view. There is another complete sheet of cut to size ply covering all of this mess, with the carpeting attached, going in and that will be like a bung, holding the transmission tunnel carpet etc in place. Bought a yoga mat this morning to use as padding/insulation as there was nothing waterproof that I have direct access to to fit to the ply and to absorb the wear of heels under the pedals. All of this has added a good 20mm or so to the floor, making the pedals easy to reach and use. ![]() Foot rest to the left was cast in Oklahoma in 2019 on the road trip and has been waiting to be used on something interesting. ![]() More in a bit about the rest of yesterday’s expectations and actions for those awake enough to have read this far. Later.
#1754 |
@nickwheeler popped over yesterday afternoon and propped up with coffee proceeded to measure, mark and cut some pipes.
Ask him about the difference between 100mm and 165mm (😁 And no, he did not screw up) ![]() Most important bend……. Negated the need for more 90’ bends and connectors. Top of radiator to thermostat entrance, somewhat offset from each other on all planes, horizontal, vertical and diagonal. Cut. ![]() Looking goooood. ![]() Air intake refitted. Awesome !!! ![]() Bottom hose was a cinch. ![]() Ohhhhh and just to mention, Nick clocked all the clamps and left it looking way too tidy. He demanded I paint the ally pipe black. I think not.
#1755 |
One of those random posts today.
As always, thanks for checking in and commenting. I have not done anything like this for some time. Well, since my charity bicycle ride a few years ago that so many people supported. And that went beautifully because people literally donated what they could. From the coins in their cars to some amazingly generous and large donations that had me choking back real tears. Sally is doing this Moon Walk from a point of real conviction and the least I can do for her is to spread the word. If you feel this is not your circus, not your monkeys, it is quite OK. But if you feel inclined to donate any amount to this worthy cause, please follow the link and donate. Sharing the link, if you feel it may help spread the word is good too. I can only thank you deeply on behalf of Sally and those who benefit from Breast Cancer research, male and female. Click the link to see more and decide if this is a worthy cause to contribute to. https://eur03.safelinks.protection.o...amp;reserved=0 Thanks again for any responses. Remember the 24th January this year. THANK YOU TO ALL WHO DONATED TO THIS WORTHY CAUSE. ![]() I believe it is still open for donations, any size would do. Sally and Sal (Sally) have completed the full Moon Walk. She reports that they are both knackered. ![]() ![]() ![]() ![]() ![]() AND THESE MEDALS ARE FOR EVERY ONE WHO PARTICIPATED. THANK YOU AGAIN. ![]() .
#1756 |
Header tank has been a PITA for @nickwheeler and I.
Various options, from a Cripple Cock cider bottle to a home made, 3” exhaust pipe tank and a walk around the bootfair today all failed. I was going to try UncleBob the hoarder to see if he had something interesting or random. Most of my day was spent around Sally, and the crazy woman, despite no sleep and doing that 26 mile night walk, fetched Bonnie and came to play with her in my garden, you call that loyal beyond any shadow of a doubt, and that is to a dog she made a covenant with. Eventually at 5.00 she went home to go crash and rest, so I went to the garage, only to get a call from @brachunky way up north on a farm, we spoke for an hour about our home town and what an 1150GS with 80k miles was worth. After that I dug out this little tank in the hope it would work as a header tank. ![]() Then realised it was just not going to be right. Planned position was drivers side inner wing. Then I fetched the original MX5 unit, oddly shaped to fit into the tight space in the engine bay. Everything back to front…… ![]() Tried to figure out how to make it work. Pulled out some compressor hose that @disasterbus dropped off here months ago. Went round to Mickey to try find some small jubilee clamps, failed, then came home and robbed two from my 7 horn La Cucheracha air horn trumpets that Nick does not like. ![]() An hour later, some brackets made, painted, the front grille moved back, to allow the hood to close. ![]() And finished. ![]() I am pleased with that. Looks good and another small job done. Planned on some painting of the boards I did for the floor yesterday, but decided a mug of tea and a cheese sandwich sounded better. Shop closed by 7.00pm. Happy.
#1757 |
The coolant overflow tank looks like it's snugged in there pretty well. Congratulations to Sally, that's a huge accomplishment. The walk and the fundraising! Funny that you mentioned the la cucaracha horns. My grandparents gave a set of those to my dad, he installed them on our Suburban, and he loved having that. My grandparents had a set on their car which my brother and I now have, that plays the bugle notes for an infantry charge.
#1758 | |
Interestingly, the quote below was from Nick who I pay around $70.00 a day to come play as pocket money (he is unemployed) and he seems to like spendingnot his own money in various ways. You might just as well as refitted the original off its blacksmith's bracket. That was just ugly; it wouldn't have annoyed you every time it ruined another MAF sensor. Not sure I understand the MAF comment. But the other bracket comment is possibly aimed at extending the time he is here on the build, getting easy money.
#1759 |
A hectic day, including 2.5 hr national meeting in which I was mentioned twice for different things, both good.
Left early and saw this threatening signage, wonder why a road being resurfaced, needs CCTV What a screwed up world this has become. ![]() Afterwards I needed a bit of random distraction. So took the seats out, cleaned the inside of the car and masked off parts of the tub, then painted. ![]() Masked ![]() One side. ![]() Both sides. Just looks tidier. ![]() I also painted all sides on the floor boards. Just to help weather proof them a bit. ![]() And all done. ![]() Binned the sponge roller I had used and cleaned up my hands, pushed the Rockit back under the roof and shut shop. Before I left, I noticed this nursery of new baby spiders. I wonder how long average house or garden spiders do live. ![]() I prefer not to mess with them.
#1760 |
So it has turned out that there are a few people who really wanted to see Napalm Nellie as baptised by @pauly rolling down Route 66 and others looking for interesting cars, trucks and life in general in the 🇺🇸
A few screenshots from chats with Dennis and JB Math again confirmed that like @alistairk experienced, there are helpful people out there. Needs to be read in sequence. ![]() ![]() ![]() ![]() ![]() ![]() Speaking with Dennis yesterday it turns out there is no title for the camper. So I think this plan will be shelved. And confirmed by JB Math as well. ![]() So for now, it seems Napalm Nellie has to be put to the side. Something else will surely pop up. Who knows.
#1761 |
Painted the lower kick panels black this morning, they may get carpet or not
![]() Nick had suggested, rightly so, that I add some padding or insulation type material to the flooring to which the carpet will be attached and wrapped around, to prevent it wearing through in days, weeks, real fast, due to heel action. So the yoga mat will hopefully be useful. ![]() ![]() After work I pulled the thick ply out, cut some templates (the two sides actually differ a lot) and drew on a pattern to cut out. Shaped, ground back, fitted…… ![]() Paint to follow later. The hole at the rear is where the roll bar will be mounted through onto the chassis. And yes, different for a reason, the seats are completely different and mounted differently. ![]() Small job done, but it saves an hour later. .
#1762 |
#1763 |
Facebook never forgets.
9 years ago I went on a long distance ride through and around South Africa with my brother for my 50th birthday. REPORT HERE: https://wilddog.net.za/threads/grizz...videos.106063/ An awesome trip, loads of places revisited from my youth and past. This morning was 9 years since I went to look at the first house I designed and built in Simonstown, near Cape Town. The builder did the columns it stood on and the shell, then I moved in and completed it. Seems I have a bit of a masochistic streak in me for longer than I recall. ![]() At 07.30 this morning I was out, painting the two sections I made last night with more battle ship grey, textured floor paint. Leaving it to dry all day. ![]() Result. ![]() Back home tonight After work I bordered all the edges of the tub in black, keep in mind, there are black carpets going in. Should blend nicely. ![]() I also gave the rear floor sections a coat of black over the textured grey paint. ![]() Took Bonnie the crazy dog for a walk on her new 10 meter, 30 foot lead and saw the first Poppies of the season. ![]() So a bit boring tonight, but more jobs that have to happen by magic, taking up time along the way. Thanks for checking in.
#1764 |
I saw this and instantly heard young @nickwheeler grinding his teeth in disdain.
![]() They are horrible things.
#1765 |
Bought some supplies on the way home.
Fresh Light Bulbs for the rear lights. Impact glue for the carpeting. ![]() ![]() Marked out on the yoga mat. Glue on both surfaces. 20 minute drying time, while I removed the masking tape from the body tub. ![]() Fits. ![]() And with the inserts in place. Plus the padded kick panels in place. ![]() Waiting for Sally to come over to make some cheese and onion wraps in the grillerI sanded back the fiberglass filler that went on into the press stud holes months ago. Rubbish stuff to flat back, but will need to be done before paint anyway. ![]() Last night I taxed UncleBob’s Bedford truck on an old J reg, Free Road tax of course. He insisted on me sending a receipt and proof of completion. So I put it in a frame for him. Tonight Sally brought me the frame back, and in it a pic UncleBob had sent me. I love the fact he was ready to bat it straight back at me. Not clear, but a load of information in the pic. Love it. ![]() Happy? Yes.
#1766 |
Sally sent a pic.
Bonnie the mad dog, loves water, and having had a couple of baths after being in mud or stinking after farm walks, now jumps in the bath herself and waits for a bath. . ![]() She is a ray of supercharged sunshine.
#1767 |
Random update.
Mate Andy in Oklahoma is building a house fir a friend. Well beyond 70, he has always got a ton of stuff going on. Sent me an update yesterday. This overlooks a river too. ![]() ![]() ![]() ![]() Have a good weekend.
#1768 |
I keep saying the same stuff over and over again, but dayjob is a pita so I need to grab bits of time to do even the most arbitrary of jobs just to get away from it.
Yesterday was Teams meetings, strategy (I hate it) and admin tasks. So my very late lunch/earlier weekend resulted in a whitewash. Hence the Billy Idol reference to bleaching. Another flashback to what was delivered on 11th September 2020 Time flies. ![]() I had tried hand buffing some of the rust stains away with G3 compound. Resulting in this. ![]() ![]() ![]() ![]() Not that impressed. So maybe a machine mopping will help, also to remove some of the grinder dust that has rusted to the flat surfaces on the body over the last 6 months of working on it. Typically, back to work, and then when I wrapped up for the week, I headed out and unpacked the car completely, sealed up exposed wiring looms and plugs etc. The pulled out the bleach, a bucket of water and a washing cloth. Big brush, bucket of bleach gel. Ideally spray the body and apply gel over water, this allows activation and oxidation to get going. Kills moulds that grow in the exposed fiberglass. ![]() Rinse. ![]() Dry, drill out drain holes for potential future puddles in the footwells. Put away and go walk the dog for 3 miles. ![]() Looks a bit cleaner. I think.
#1769 |
Another job I did late last night was to clearance the hood/bonnet to fit flush around the wiring loom grommets.
![]() ![]() And went for a 3 mile walk with Sally and Bonnie the dog…… Saw this road, down which we walked…… report in the Chevy S10 thread elsewhere. Or to followon other forums. Maybe it is a sign. Hell, I do hope so. ![]() Time to get this thing wrapped up, but we know there are loads of jobs. Yes, they keep coming.
#1770 |
Went for a 3 mile or 5km walk with Sally and the Dog Bonnie.
Walking down this road, I hoped it was a sign. ![]() WW2 pill box. ![]() Zooming on, on the Thames river banks. ![]() Weird patterns of death in the wheat fields. ![]() Sheep, should taste really good feeding on the salt marsh grass. ![]() Amazing stuff the tides bring in. Just not easy to access, and a long walk to carry home. ![]() And the tide washed up a truck. Tempted to carry it home….. Sally just laughed and laughed. ![]() Back on the Rezin Rockit build today.
#1771 |
Yesterday was one of those extremely rewarding days.
Very little to show for it. But a big step forward toward getting the car safe and on the road. Remember the 5 point racing harnesses Dennis sent me recently? Time to break them out. After all…… Safety. ![]() ![]() For all the zoooomers you can see the basic profile for the roll bar drawn on the blue card. So the shoulder straps get bolted to the shoulder high cross bar. Lap straps are bolted to the chassis through the transmission tunnel and on the seat where the original seatbelt locking cable used to sit. Floor mounted crotch strap is again bolted to a cross brace. With all of these points established, it was time for what turned into a big job, small evidence, but great outcome, like a 1 carat diamond engagement ring. 10mm steel plate that has been on standby for 12 years, retrieved and cleaned up. ![]() Big ass grinder fetched from the darkest corner of the garage, safety boots pulled on, new steel cutting blade attached. Cardboard template copied onto the steel, hearing protection, glasses. Footplates Cut. ![]() One Cleaned up. ![]() Pair of them. ![]() Then more measure, plan, cardboard, copy, cutting. ![]() Try for size ![]() Much drilling, bolting, visualisation Paint can caps representing a large diameter roll bar welded onto the mounting plate. ![]() ![]() Next up, cut the heads off some bolts to leave decent studs. Chamfer rears to ensure good contact and penetration of weld. Weld into place, test roll bar mounting plate fit, grind back welds. ![]() ![]() Disassemble and set up in modern spray booth for paint. ![]() Paint, walk away, allow to dry, return, flip over paint and leave to dry. ![]() Very happy with this result. Close shop at 6.15, pour a heavy gin and tonic in a pint glass, drink, go shower, pour another pint of mothers milk. Relaxxxxxxx. Then John the lodger got in around 7.30 and offered to buy us a take out Indian curry meal. I was certainly not going to cook, offered to pay my way, he declined. ![]() Dinner was good. Sleep was not. Awake by 3,45 and out to a disappointing bootfair by 05.45 But managed to get 11 pairs of safety glasses for £10.00 and also some foam squares to glue to the inner scuttle/firewall 4 for £1.00 ![]() Should work a treat. Breakfast next.
#1772 |
@nickwheeler" wrote the following up:
No precision was wasted making these parts . It was time to do something about these ghetto hose-separators: ![]() The hoses are 7/8" diameter, and the bulkhead fitting spaces them 38mm apart. Scribe some that looks about right marking to some 8mm aluminium plate: ![]() Hack off, and clamp to the mill - a drill press would do - and drill four 22mm holes because that's close enough to 7/8": ![]() I milled two straight and parallel edges because I could, but that could have been done with a file. Hacksaw them apart, and lop off the corners: ![]() Mill the new edges straight and parallel to the originals, and shape the ends with files: ![]() Like this: ![]() I rubbed them across 120 and 240 grit DA discs on a piece of granite, using plenty of glass cleaner for a smooth, bushed finish.. No pics, as I did that in between dinner and going out. Old vs New ![]() And on the car: ![]() The 22mm holes are slightly looser than I'd like, and will benefit from a touch of black silicone next time we have some out. Much happier.
#1773 |
Did I mention that Sunday was a busy day.
Loads of yard work etc. Eventually got started on the car, working on the floor, fitting the seats etc. Nick and I had planned a few progress jobs. Get the brakes bled through, get onto the rear lights, in order to button that up. And then this week @nickwheeler remembered he had a large kit to pressure test cooling systems. So the cooling system prime and test was on the cards. While I carried on with my jobs, he fetched a watering can of water, called for a large funnel to fill the radiator and cooling system. I carried on cutting metal and drilling, my power tool noise induced reverie suddenly torn apart by Nicks scream of disdain (OK maybe I have exaggerated) So I flew to his side to find this. Look closely, look again. Pssssssssssss…… ![]() After some weird angle photos, and a bit of wriggling, pulling and pushing and loosening, Nick had a trophy. ![]() Problem. ![]() Some internet research showed that this is a known weakness in these engines. Poop. ![]() Clearly, being a known and recurrent fault, has led to it to be exploited to the max. Crazy money. ![]() I managed to contact an independent who agreed to selling me a used part for a 1600cc engine at £40.00, just need to make a gasket, used to have gasket paper…. A long time ago. Another job planned was the brakes. Errrrmmmmmm….. No, not happening. A long time ago, the one brake hose that came with the car, seemed perfectly fine. On Sunday, no flow, either with pressure or suction. So using the last of the braided hose, Nick made a new brake hose. Testing the old pipe, with a stainless steel welding rod it seemed it was blocked solid. At the rear a similar scene played out as well. Bloody soul destroying. ![]() ![]() ![]() ![]() So there you go. Still no start. As Quoted: What is it they say, 90% done, 90% to go I like that.
#1774 |
Well
That used part did not work. Part he had to sell was wrong side. After some digging around he pulled one out. But same flaw and damage. Walked Away. Around the corner to an engineering shop. Where the shift extension came from. 20 minutes consultation later…… I will try fix it myself. Drill this out @8.5mm ![]() ![]() Then tap and fit this. ![]() Delivery 9-16 June. Wonder if they are delivering on foot.
#1775 |
Came home today and the mailman had delivered a new edition of the Illinois Route 66 guide for me.
Thanks @jagwinn for taking the time to show me a kindness when it was needed. ![]() Guess it means a road trip has kinda got to be done.
