05-21-2022, 03:35 AM | #1 |
Vortec 5.7 Mystery Sound
Hi All,
I just installed a 350 Vortec from a '99 pickup into my 66 C20 that has a 700r4. On first start up I heard this god awful noise and could see some deflection from the front pulley so ordered a new one and replaced it. The sound persists. To me it sounds too fast to be a stuck lifter. I took the belt off and the sound remains as I thought it sounded fast enough to be the water pump impellor. My problem is that I'm mostly deaf so I can't actually tell which part of the drivetrain it is coming from. Flexplate bolts fouling to front timing chain I have no idea. Would anybody be able to have a guess as to what it is? https://youtu.be/4jvq_UoU3M4 Thanks in advance. |
05-21-2022, 10:42 AM | #2 |
Re: Vortec 5.7 Mystery Sound
Did you have the motor apart at all or just install it and run it?
Make a listening device from a funnel stuck on the end of a heater hose to pinpoint the location. Not a lifter sound. More like crank hitting something. Pull the oil dipstick out and see if it changes. |
05-21-2022, 12:09 PM | #3 |
Did you buy the engine from a reputable business? I take it you didn't hear it run before you bought it. A 23 year old engine is a "pig in a poke", condition unknown. You may find this noise to be a symptom of something major. Unless you enjoy treasure hunting, get in touch with who you bought it from and get either a refund or replacement.
05-21-2022, 01:42 PM | #4 |
driving is in my blood
If its a stock timing cover, did you plug the crank sensor hole somehow?
If its a metal cover, did you remove the crankshaft reluctor ring that triggers the crank sensor? It sounds bad. I'd take that engine apart.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
05-21-2022, 02:57 PM | #5 | |
The engine was from an Importer (I'm in New Zealand) and is under warranty. I'm hoping to fix it as it has good compression and it will be a ball ache to take it out and ship it back to the South Island. Edit: So I went to pull the dipstick out as it is a mile long and was quite difficult to get to slide back in when filling with oil originally. Hit the starter and just grinding. I have the inspection plate off already but will hone in on the starter to see if that is the problem. The flexplate is new and not wobbling but at rest the ring gear is very close to the teeth of the starter. In my experience usually it makes a high pitch grinding noise but I'm curious. Hopefully my old 283 mini high torque starter is a bolt on swap and I can test with that. Last edited by dmulally; 05-21-2022 at 03:18 PM. |
05-21-2022, 04:48 PM | #6 |
OK looks like I found the problem. The starter motors weren't interchangable but I thought I'd take it out anyway. One of the bolts was 10mm out of position and just spinning when trying to tighten up. I was going to re-tap the thread so went to take the other bolt out and noticed it was a larger size bolt.
A couple of turns of the larger bolt later and part of the block fell off. Time to start the warranty process I guess. Thanks for the responses, lads. |
05-21-2022, 05:06 PM | #7 |
And thank you for the memory jog!
We were in your area back in ‘91 when on holiday. Stayed at Foxton Beach a couple days. Too bad about the block. Good you have a warranty. |
05-21-2022, 06:26 PM | #8 | |
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
05-21-2022, 07:35 PM | #9 | |
Moderator
BTW, 283 mini starters have a different mounting bolt pattern and bolt size. Thee sections of the block rear edge where the starter mounts commonly break off if the wrong bolts and or starter are used and the starter end brace back to the block is missing. Best of luck
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
05-21-2022, 11:14 PM | #10 | |
Fascinating what they did with the area. A decade ago plenty of bikies used to use the place as a hang out until the council bought them all out. I bet you'd be shocked with how gentrified it is these days! |
05-21-2022, 11:15 PM | #11 |
