05-06-2009, 07:28 PM | #1 |
donors
which newer chevys can donate parts for my 62. such as front end rear end steering components, anything else that can be bolted on.
thanks josh |
05-06-2009, 07:33 PM | #2 |
Resistance is Futile
Re: donors
73-87 will work.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
05-06-2009, 07:44 PM | #3 |
Re: donors
is that the only years nothin newer.
05-06-2009, 09:19 PM | #4 |
Watch out for your cornhole !
Re: donors
He gave a good answer.
73-87 gives the front suspension, steering, and rearend with some mods. In 88, lots of stuff changed. The suspension no longer interchanges, or the steering. I'm using an 80 model as my donor.
05-06-2009, 10:07 PM | #5 |
Re: donors
the search feature will answer your questions
CHEVY ONLY |
05-06-2009, 10:18 PM | #6 |
Re: donors
my search feature at the top of the page is not working. is this only 73-87 chevy trucks or most chevy cars and trucks within those years. i have heard that a cavalierfront end will bolt right up but i need more info than just an "i think it will". could i possibly get a short list of good donor vehicles.
thanks josh |
05-06-2009, 10:21 PM | #7 |
Re: donors
are you using the blue theme, if so that is your problem....switch to the gray theme and all will be right again...
I would knee jerk react and think that whom ever told you cavalier doesn't have a clue...they are front wheel drive, correct??? 73-87 gives you all kinds of options and they are cheap and plentiful... BTW...I graduated from Stratford
CHEVY ONLY Last edited by joe231; 05-06-2009 at 10:22 PM. |
05-06-2009, 10:26 PM | #8 |
Re: donors
ah front wheel drive, now i feel like an idiot for even mentioning that one. so as long as it is rear wheel driven and between 73-87 it might work. thanks for the info, off to search ebay.
thanks josh |
05-06-2009, 10:30 PM | #9 |
Re: donors
'73-87 1/2 ton trucks if you want 5 lug, 3/4 if you want 8 lug, and the crew cabs and suburbans up to '91.
you can get a '71-72 1/2 ton 5lug axle that is pretty much a blot in, jut a bit wider
CHEVY ONLY |
05-06-2009, 10:50 PM | #10 |
Re: donors
how hard would that be to correct
05-06-2009, 10:51 PM | #11 |
Re: donors
Thanx Joe, I didnt think of the 71-72. They also work equally well but may have a couple parts that are more rare(= more $). Somewhere along the way, roughly 1980, you will start getting into metric parts, FYI.
05-06-2009, 10:52 PM | #12 |
Re: donors
You dont have to correct anything....just watch your wheel offset/backspace.
05-06-2009, 10:52 PM | #13 |
Re: donors
oops bolt in
how hard would what be to correct? my mis-spelling? or the axle width?
CHEVY ONLY Last edited by joe231; 05-06-2009 at 10:54 PM. |
05-06-2009, 11:35 PM | #14 |
Re: donors
the axle width is what i was talking about
05-06-2009, 11:38 PM | #15 |
Re: donors
05-06-2009, 11:45 PM | #16 |
60-66 Nut
Re: donors
Wheel offset/backspacing is referring to the distance from where the wheel bolts to the axle flange, to the inside lip of the wheel. If you use a differential that is a different width, you may need to use wheels that have a particular or special backspacing.
05-07-2009, 08:47 AM | #17 |
Re: donors
would there be a problem with the steering colum out of a chevy that is between 2000-09 or any of the other interior parts such as window motor and seats. the donor could be an avelanche don't know the year but it is fairly new.
05-07-2009, 09:19 AM | #18 |
Re: donors
first off...are you looking for bolt in?
you can do practically anything if you have the time, money, and patients. I don't think the column will be an easy swap, but the seats may fit....
CHEVY ONLY |
05-07-2009, 10:13 AM | #19 |
Re: donors
ok thats all i needed to know.
thanks josh |
05-07-2009, 12:44 PM | #20 |
Re: donors
That column and it's airbag are worth enough coin to buy a nice tilt column for your truck that will basically fit without any mods.
05-07-2009, 03:23 PM | #21 |
Sunburst C10!!!
Re: donors
how much wider is the 71-72 rear axle than the 60-66
Gage 1967 C10 Shortbed Stepside |
05-07-2009, 03:30 PM | #22 |
Re: donors
1.5 inches wider.
Don't sweat it though, the front end with disc brakes is also 1.5 inches wider too. It's a non issue really. Just compensate by running an extra 1/2 inch of backspacing on your wheel choice and all is a moot point.
05-07-2009, 03:47 PM | #23 |
Sunburst C10!!!
Re: donors
i have a 72 rear axle in my truck i was going to narrow it a couple inches on each side to make clearance for wider tires and get aftermarket axles
but i will just get a 60-66 axle
05-07-2009, 05:05 PM | #24 |
Re: donors
would the seats and window motor out the the newer avelanche work in the 62. my reasons for asking is a guy i know has a wrecked one that i might be able to get some of these parts off of for maybe cheaper than i could somewhere else.
05-07-2009, 11:07 PM | #25 | |
60-66 Nut
Re: donors
