09-06-2021, 03:04 PM | #1 |
AC Blend door "clip"?
Taking the heater core out of my dads 83 Truck and found a broken plastic connector that moves the blend door via the vac pod from the opposite side. I know GM has them for about 3-4 dollars, but I've found one out of either aluminum or steel--but really 30 plus dollars each? yikes!! Any vendor on the board here have it?? Looking to get a couple of them for future endeavors and one for my suburban if there is ever an issue with it.
09-06-2021, 03:07 PM | #2 |
Re: AC Blend door "clip"?
This little jewel
09-07-2021, 06:13 AM | #3 |
Post #35 in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=460942 shows my homemade metal solution. It is still working today.
09-15-2021, 04:46 PM | #4 |
I just ordered one of the aluminum ones off of ebay. Buy once, cry once.
But can someone tell me how the blend door works? Is there a way to test function? I have my dash all pulled apart at the moment and want to make sure everything is working properly when it goes back together. |
09-15-2021, 08:21 PM | #5 | |
Moderator
Vacuum on newer machines and cable on the older machines.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
09-15-2021, 09:54 PM | #6 |
I sucked it up and got 2 aluminum ones. One for my suburban and one for the dads truck. They arrived today as a matter of fact
09-16-2021, 05:10 PM | #7 | |
Guessing the engine has to be running (to produce vacuum) but what else makes it move back and forth? I want to make sure everything is working as it should before I put all the ductwork etc back in place. |
09-16-2021, 05:51 PM | #8 | |
Moderator
This is supposed to be the HVAC Vacuum diagram for a K5.
09-20-2021, 01:10 PM | #9 | |
09-26-2021, 03:39 PM | #10 | |
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
09-26-2021, 04:06 PM | #11 |
09-27-2021, 08:36 PM | #12 |
Well then just get a solid round alum rod big enough from home depot. Cut off a section use hack it with Dremel Tool and Accessories. Cut and grind in to shape in 2 hour you should be able get it rough out the Chinese alum test fit fine tuning it for fitment. You can spend as much to finish it to your liking. I did not know you did not want Chinese plastic. The shape is not hard to make. The other option is pc 3D printer buy one or try calling 3D printer shop to do some up for you.( but Plastic again)
09-27-2021, 11:42 PM | #13 | |
01-01-2022, 06:18 PM | #14 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-02-2022, 09:34 AM | #15 |
Go to Ebay, type in a/c heater blend door clip. Several pop up.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
01-03-2022, 01:28 PM | #16 |
Moderator
If you can run a grinder and MIG you can DIY one out of steel.
01-05-2022, 01:17 PM | #17 |
Thanks! I ordered one of the aluminum pieces. Hopefully I will never have to replace it again. On another note, where are you guys sourcing quality heater cores? TIA!
