09-15-2021, 06:25 PM | #1 |
Air breather to fit Holley 4150??
Which inexpensive air cleaner will fit Holley 4150 carb? The zone has the basic edelbrock triangular metal hole filter around $30....If it'll fit I just grab it..not sure??? Or one the basic round drop base filters...
: Eli540 86 gmc 2500 longbed Carb 5.7, rwd, 400 tranny. |
09-15-2021, 07:53 PM | #2 |
Re: Air breather to fit Holley 4150??
You might not have room for a drop base cleaner. You could have interference with the distributor.
A generic chrome air cleaner is all you need. If you like engine fires then buy the triangle edelbrock one. They are known to light on fire if you get a back fire. One like this would work. https://www.summitracing.com/parts/p...yABEgJ29vD_BwE |
09-15-2021, 09:13 PM | #3 |
just don't fall for the oil cleaned K&N nonsense, get the tallest one you can fit under the hood from Summit
09-15-2021, 10:00 PM | #4 |
Edelbrock 10" 1208 (chrome) or 1203 (black)
Discard the original filter (if you wish) and use a CA160, CA192, CA3588 depending on height desired |
09-16-2021, 12:00 AM | #5 |
I used the 60s 70s Chevy HP open drop housing. It fits fine with HEI and uses Corvette PCV and breather set up.
NAPA 6096 is a nice 14" X 4" filter with a foam wrap. WIX #46096. http://67-72chevytrucks.com/vboard/s...d.php?t=643974
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
09-16-2021, 07:37 AM | #6 |
I used a Speedway Motors 10" Inch Low Profile Small Chrome Air Cleaner.
https://www.ebay.com/itm/13337415515...4664ddfa0827c0
